I am installing BigBlueButton inside an LXC container. However there are some services that fail to start without modifications (they obviously work fine in a normal, non-virtualized installation).
The error in all the cases is: status=214/SETSCHEDULER
The options that need to be commented out are
When they are commented out the services start without problems.
I am not a kernel expert, but it seems like the LXC containers need the capability CAP_SYS_NICE in order to be able to set a realtime scheduler.
I tried to set it to my container with a command like this:
lxc config set BBB raw.lxc=lxc.cap.keep=sys_nice
However the container wouldn’t start afterwards. The command lxc console BBB --show-log displays:
Failed to mount tmpfs at /dev/shm: Operation not permitted
Failed to mount tmpfs at /run: Operation not permitted
Failed to mount tmpfs at /run/lock: Operation not permitted
[!!!!!!] Failed to mount API filesystems.
Exiting PID 1...
Maybe this is not the right way to do it.
Do you have any suggestions?
In this case the services can start without modifications.
But this has drastic security implications (I guess). So, I would prefer to grant only the minimum of necessary permissions (in this case the capability CAP_SYS_NICE), if possible.
Also, a way to find out whether this capability is already granted inside a container or not, would be useful.
# If CAP_SYS_NICE is not available, then the FreeSWITCH systemctl service
# will fail to start, with an error message like "status=214/SETSCHEDULER".
# In this case we need to modify this service so that it does not require a realtime scheduler.
# A similar modification needs to be done to a couple of other services as well,
# like: bbb-html5-frontend@.service, bbb-html5-backend@.service and bbb-webrtc-sfu.service
check_cap_sys_nice() {
# if we don't detect a SETSCHEDULER error message in the status of the service,
# then there is nothing to be modified/customized
{ systemctl status freeswitch | grep -q SETSCHEDULER; } || return
# override /lib/systemd/system/freeswitch.service so that it does not use realtime scheduler
mkdir -p /etc/systemd/system/freeswitch.service.d
cat <<HERE > /etc/systemd/system/freeswitch.service.d/override.conf
[Service]
IOSchedulingClass=
IOSchedulingPriority=
CPUSchedulingPolicy=
CPUSchedulingPriority=
HERE
# override /usr/lib/systemd/system/bbb-html5-frontend@.service
mkdir -p /etc/systemd/system/bbb-html5-frontend@.service.d
cat <<HERE > /etc/systemd/system/bbb-html5-frontend@.service.d/override.conf
[Service]
HERE
# override /usr/lib/systemd/system/bbb-html5-backend@.service
mkdir -p /etc/systemd/system/bbb-html5-backend@.service.d
cat <<HERE > /etc/systemd/system/bbb-html5-backend@.service.d/override.conf
[Service]
HERE
# override /usr/lib/systemd/system/bbb-webrtc-sfu.service
mkdir -p /etc/systemd/system/bbb-webrtc-sfu.service.d
cat <<HERE > /etc/systemd/system/bbb-webrtc-sfu.service.d/override.conf
[Service]
HERE
systemctl daemon-reload
This is really useful. I tried something like this:
lxc config set BBB \
security.syscalls.intercept.sched_setscheduler=true
lxc restart BBB
And the error message status=214/SETSCHEDULER was gone.
However now I get another error message: status=211/IOPRIO.
I believe that it is related to CAP_SYS_ADMIN (which is almost the same as a privileged container) and it is caused by these systemd config lines:
