I have a host PC with a bridge to the wired Ethernet for general use Internet and a Wireguard client to a off-site server to access the LAN at the off-site.
From the host PC I can connect to the internet and the off-site LAN.
From inside the unprivileged lxc containers I can connect to the internet since I shared the bridge with the container using:
How would I go about sharing also the Wireguard connection.
this is the output from nmcli:
NAME UUID TYPE DEVICE
br0 ab860abc-3202-4400-aa5e-725ab5efdd71 bridge br0
Malital a1a5c64a-4c9c-4d43-b3f2-11d5bca21e23 wireguard Malital
bridge-slave-enp1s0 2e3b78b5-c473-4d7d-a061-92284e22aa61 ethernet enp1s0
lo 0784ee26-0ec5-453a-8171-edceb4fb3c6e loopback lo
Sienja dc6bf384-aa95-4028-b6aa-77142da227b5 vpn --
Simar 4a657a69-95a9-4258-813e-fa6e95d05e63 vpn --
Wired Connection 16813991-938d-45cb-9002-5a25219f4cba ethernet --
I have tried adding the wireguard connection to br0 but that didn’t work.
I tried creating a new bridge (br1) and adding the wireguard connection to it and sharing this second bridge with the container. I could then ping the second bridge, the wireguard client ip but not the off-site clients.
I tried directly sharing the wireguard connection with the LXC but the container doesn’t even start.
I know I can install wireguard inside the client and that is the solution I am currently using but I have 3 containers accessing the off-site and it seems silly to have 3 tunnels in lxc + 1 tunnel on host fired up.
Thanks for you reply. I am under the impression that all packets from the container hit the bridge br0 and if I tcpdump from the host the br0 interface I can see the packets. Both those intended for the internet and the wg0. But they stop there and are not forwarded to the wg0.
Packets from the host intended to the wg0 are routed correctly.
How do I get to forward the packets arriving at br0 intended for wg0 to be routed accordingly.
Sorry for the formatting. Adapted from AI answer. Make sure you research and understand why and how these commands are needed and used before adapting them to your setup. Firewall rules can also be added but for lan setup the nat rule probably is sufficient.
