Not sure what you mean. If you want the list of addresses that LXD is listening on on a remote server, lxc info will have that in the addresses section.
If you want the list of network interfaces on the LXD server, lxc network list will show you a list. Those manages by LXD will show their IPv4/IPv6 addresses there. Those not managed by LXD you can query with lxc network info NAME and you’ll get the details then.
Being a lazy sysadmin, it would be good to see the subnet in use on the remote lxdbr0 interface in the output of lxd remote list. For instance, say I have 3 remote LXD hosts. Instead of logging into each of them to determine this, it would be good to have something like below (see the last column of what I’m after):
lxc remote list
| NAME | URL | PROTOCOL | AUTH TYPE | PUBLIC | STATIC | GLOBAL | SUBNET |
| lxdhost1 (current) | https://lxd1.domain.com:8443 | lxd | tls | NO | NO | NO | 10.1.0.0/24 |
| lxdhost2 | https://lxd2.domain.com:8443 | lxd | tls | NO | NO | NO | 10.2.0.0/24 |
| lxdhost3 | https://lxd3.domain.com:8443 | lxd | tls | NO | NO | NO | 10.3.0.0/24 |
| images | https://images.linuxcontainers.org | simplestreams | none | YES | NO | NO | none |
| local | unix:// | lxd | file access | NO | YES | NO | 10.0.0.0/24 |
| ubuntu | https://cloud-images.ubuntu.com/releases | simplestreams | none | YES | YES | NO | none |
| ubuntu-daily | https://cloud-images.ubuntu.com/daily | simplestreams | none | YES | YES | NO | none |
All this to promote sheer laziness. But I have a feeling I’m not alone.
Ah yeah, no, we’re not going to do that.
You can have MANY networks, I have production deployments with over 50 bridges on some systems. Also, lxc remote list is a local-only command. It doesn’t make any API calls whereas this would require a whole bunch of them.
I’m afraid you’re going to have to stick to lxc network list remote:
