I am experimenting with LXD on Ubuntu 20.04 (in virtualboxes). I have tested this with LXD 4.0.3 (which is apparently what comes installed in 20.04) and 4.6 (which is what I get if I do snap remove and snap install lxd). On node1, I do:
sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What name should be used to identify this node in the cluster? [default=lxd-node1]:
What IP address or DNS name should be used to reach this node? [default=192.168.0.26]:
Are you joining an existing cluster? (yes/no) [default=no]:
Setup password authentication on the cluster? (yes/no) [default=yes]:
Trust password for new clients:
Again:
Do you want to configure a new local storage pool? (yes/no) [default=yes]:
Name of the storage backend to use (dir, lvm, zfs, btrfs) [default=zfs]: dir
Do you want to configure a new remote storage pool? (yes/no) [default=no]:
Would you like to configure LXD to use an existing bridge or host interface? (yes/no) [default=no]:
Would you like to create a new Fan overlay network? (yes/no) [default=yes]:
What subnet should be used as the Fan underlay? [default=auto]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
On the second node, I do:
lxd-node3:~$ sudo lxd init
What name should be used to identify this node in the cluster? [default=lxd-node3]:
What IP address or DNS name should be used to reach this node? [default=192.168.0.28]:
Are you joining an existing cluster? (yes/no) [default=no]: yes
IP address or FQDN of an existing cluster node: 192.168.0.26
Cluster fingerprint: d153628c8839398b9aeb77735ea0bbd86050917e9c924379ff7cf0ca8a09a459
You can validate this fingerprint by running "lxc info" locally on an existing node.
Is this the correct fingerprint? (yes/no) [default=no]: yes
Cluster trust password:
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose "source" property for storage pool "local":
After this, I get with lxc cluster list
| NAME | URL | DATABASE | STATE | MESSAGE | ARCHITECTURE | FAILURE DOMAIN |
| lxd-node1 | https://192.168.0.26:8443 | YES | ONLINE | fully operational | x86_64 | default |
| lxd-node3 | https://192.168.0.28:8443 | NO | ONLINE | fully operational | x86_64 | default |
Why is the second node (lxd-node3 in my case) NO? Should it not be replicated?
