I am installing lxd on a raspberry pi4 running archlinux (arm). I have zfs installed on the system, which is working fine.
$ zpool version
zfs-2.1.0-1
zfs-kmod-2.1.0-1
Unfortunately, lxd is not detecting ZFS.
$systemctl reload snap.lxd.daemon
$lxd init
WARNING: cgroup v2 is not fully supported yet, proceeding with partial confinement
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (ceph, btrfs, dir, lvm) [default=btrfs]: zfs
Invalid input, try again.
$snap info lxd
installed: 4.18 (21461) 55MB -
That’s correct, we only support ZFS on 64bit architectures.
ZFS on 32bit, while it’s something you can build, it tends to have quite a lot of weird behavioral issues coming from the fact that upstream primarily focuses on 64bit (and effectively always has).
Any reason you’re running a 32bit distro on your Raspberry Pi4?
We have 3 of those in our lab and usually run 64bit distros (Ubuntu 20.04 mostly) with LXD then running very happily with ZFS and even giving us VM support.
I need JAVA 11 to run openHAB and unfortunately it is not available on arm64. Only version 15 and 16 are available for arm64. Thus i am forced to use 32bit.
