I would like to use the host uid/gid 140:140 in an alpine image. This uid/gid is for mysql. On the host i have
$ cat /etc/subuid
root:1000000:65536
root:140:1
$ cat /etc/subgid
root:1000000:65536
root:140:1
In the lxc container i have defined,
raw.idmap: both 140 140
sharedb:
path: /var/lib/mysql
source: /var/lib/mysql
The host lists the files as:
# ls -l /var/lib/mysql
total 528
-rw-rw---- 1 mysql mysql 24576 Apr 1 09:36 aria_log.00000001
-rw-rw---- 1 mysql mysql 52 Apr 1 09:36 aria_log_control
drwxr-xr-x 2 mysql mysql 3 Mar 30 05:26 innodb
drwxr-xr-x 2 mysql mysql 4 Mar 30 05:58 logs
-rw-rw---- 1 mysql mysql 0 Dec 17 01:28 multi-master.info
drwx------ 2 mysql mysql 89 Mar 30 07:44 mysql
-rw-rw---- 1 mysql mysql 0 Apr 1 09:31 mysql-bin.index
-rw-rw---- 1 mysql mysql 2119122 Dec 17 01:32 mysqld-bin.000001
-rw-rw---- 1 mysql mysql 20 Dec 17 01:30 mysqld-bin.index
-rw-rw---- 1 mysql mysql 9 Dec 17 01:32 mysqld-bin.state
drwx------ 2 mysql mysql 309 Mar 30 07:51 mythconverg
drwx------ 2 mysql mysql 3 Dec 17 01:28 performance_schema
drwx------ 2 mysql mysql 2 Dec 17 01:27 test
However in the container the logs and innodb folder still have ‘nobody:nobody’ set instead of mysql.
# ls -la /var/lib/mysql/
total 537
drwxr-xr-x 10 mysql mysql 17 Apr 1 09:33 .
drwxr-xr-x 6 root root 6 Apr 1 03:37 ..
drwxr-xr-x 2 nobody nobody 2 Mar 30 07:04 innodb
drwxr-xr-x 2 nobody nobody 2 Mar 30 11:07 logs
All the other directories have uid/gid of mysql except innodb and logs!. Any idea why is that?
Mysql config my.cnf in the container is,
# cat /etc/mysql/my.cnf
[client]
port = 3306
socket = /run/mysqld/mysqld.sock
[mysqld]
port = 3306
skip-external-locking
key_buffer_size = 16M
max_allowed_packet = 200M
table_open_cache = 64
sort_buffer_size = 512K
net_buffer_length = 8K
read_buffer_size = 256K
read_rnd_buffer_size = 512K
myisam_sort_buffer_size = 8M
bind-address = 0.0.0.0
log-bin=mysql-bin
binlog_format=mixed
server-id = 1
innodb_buffer_pool_size = 20G
innodb_data_home_dir = /var/lib/mysql/innodb
innodb_data_file_path = ibdata1:10M:autoextend:max:128M
innodb_log_group_home_dir = /var/lib/mysql/logs
innodb_data_file_path = ibdata1:10M:autoextend:max:15G
innodb_log_file_size = 256M
innodb_log_buffer_size = 16M
innodb_log_files_in_group=2
innodb_flush_log_at_trx_commit = 2
innodb_lock_wait_timeout = 50
innodb_write_io_threads = 8
innodb_read_io_threads = 8
innodb_autoinc_lock_mode = 2
innodb_file_per_table=off
skip-innodb_doublewrite
[mysqldump]
quick
max_allowed_packet = 16M
[mysql]
no-auto-rehash
[myisamchk]
key_buffer_size = 20M
sort_buffer_size = 20M
read_buffer = 2M
write_buffer = 2M
[mysqlhotcopy]
interactive-timeout
