I haven’t run this cmd yet. Currently, I can’t reach my server.
Let’s say I have a btrfs volume running instances.
When I use incus storage volume export, it’s recommended to stop all instances when running this cmd? I only concern about data stored in disk.
I roughly remember a volume contains container folder, VM folder and some config folders. Let’s say only a project using this volume, and all setting won’t break in another server. Can I restore the volume to another incus server? I just don’t know how incus database work.
If I run a oci container with a custom volume, this custom volume is a subvolume of the btrfs volume, will the subvolume be exported when export?
If all instances were created from a snapshot of an instance. When export without --optimized-storage, does each instance still a extend of the snapshot, or will copy the snapshot with extend data to form a completely new object.
