Hi all,
I have an LXD container with an LVM storage pool. The container already has several snapshots.
Today, I made some modifications inside my container (installations/upgrades of some packages). After running these modifications I run df -h
inside the container and noticed that the total space had increased of about 3GB. Later during the day, I eventually decided to restore the container to the latest snapshot which discarded the changes I had made earlier today. Running df -h
again inside the container, I could see that the additional 3GB were “freed”.
However, when I run df -h
outside the container (on my server) I see an increase of 3GB.
Where did the extra 3GB go ? Where is it stored ? On the LVM storage pool ? Is there a way to free this space ?
The command lxc storage info lvmpool
returns:
info:
driver: lvm
space used: 43.22GiB
total space: 137.70GiB
while sudo du -h /var/snap/lxd/common/lxd/disks/lvmpool.img
returns
53G /var/snap/lxd/common/lxd/disks/lvmpool.img
and lxc storage show lvmpool
returns
lvm.thinpool_name: LXDThinPool
lvm.vg_name: lvmpool
source: /var/snap/lxd/common/lxd/disks/lvmpool.img
volume.size: 50GB
Unfortunately, I do not know whether the output of any of the above commands was different before I started modifying my container.
Thanks a lot and apologies if this seems like a n00b question.
