This is a transcript of a ssh attempt from container (ubuntu:xenial) to host:
ubuntu@clever-skink:/workspace$ ssh -v mcon@192.168.7.168
OpenSSH_7.2p2 Ubuntu-4ubuntu2.10, OpenSSL 1.0.2g 1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 192.168.7.168 [192.168.7.168] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/ubuntu/.ssh/id_rsa type -1
debug1: identity file /home/ubuntu/.ssh/id_rsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_dsa type -1
debug1: identity file /home/ubuntu/.ssh/id_dsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_ecdsa type -1
debug1: identity file /home/ubuntu/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_ed25519 type -1
debug1: identity file /home/ubuntu/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.10
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.3 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.7.168:22 as 'mcon'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:qn+LkwK3IIfsSjen7t569aXQWirJApMtvAdvLXRs/ZE
debug1: read_passphrase: can't open /dev/tty: No such device or address
Host key verification failed.
Of course /dev/tty is there and it’s world-read/write:
ubuntu@clever-skink:/workspace$ ls -l /dev/tty
crw-rw-rw- 1 nobody nogroup 5, 0 Aug 19 22:54 /dev/tty
Before launching ssh
I had (I’m unsure if this is relevant):
mcon@cinderella:~$ lxc exec clever-skink -- bash
root@clever-skink:~# ls -l /workspace/
total 4
drwxrwxr-x 4 ubuntu ubuntu 4096 Aug 19 13:23 Quectel
root@clever-skink:~# su ubuntu -
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
ubuntu@clever-skink:/root$
Note that running the same command as “root” works as expected.
This holds true also for other devices (e.g.: /dev/stderr) which are not usable by “normal user”.
Also using other “tricks” to drop privileges (e.g.: “lxc exec clever-skink – su --login ubuntu”) have similar problems.
What am I doing wrong?
