Getting error while trying to start stopped container
root@node25:~# lxc start remote-akhila
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart remote-akhila /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/remote-akhila/lxc.conf:
Try lxc info --show-log remote-akhila for more info
result of running “lxc info --show-log remote-akhila”
lxc remote-akhila 20211018105956.709 TRACE start - start.c:lxc_end:985 - Set container state to “STOPPED”
lxc 20211018105956.709 ERROR commands - commands.c:lxc_cmd_rsp_recv_fds:129 - Failed to receive file descriptors
lxc 20211018105956.709 TRACE commands - commands.c:lxc_cmd:518 - Opened new command socket connection fd 32 for command “get_state”
lxc remote-akhila 20211018105956.727 INFO conf - conf.c:run_script_argv:342 - Executing script “/snap/lxd/current/lxcfs/lxc.reboot.hook” for container “remote-akhila”
lxc remote-akhila 20211018105956.727 TRACE conf - conf.c:run_script_argv:385 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc remote-akhila 20211018105956.727 TRACE conf - conf.c:run_script_argv:390 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc remote-akhila 20211018105957.234 INFO conf - conf.c:run_script_argv:342 - Executing script “/snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd “default” “remote-akhila” stop” for container “remote-akhila”
lxc remote-akhila 20211018105957.234 TRACE conf - conf.c:run_script_argv:385 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc remote-akhila 20211018105957.234 TRACE conf - conf.c:run_script_argv:390 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc 20211018105957.337 TRACE commands - commands.c:lxc_cmd:511 - Connection refused - Command “get_state” failed to connect command socket
lxc 20211018105959.330 TRACE commands - commands.c:lxc_cmd:511 - Connection refused - Command “get_state” failed to connect command socket
lxc 20211018110444.192 TRACE commands - commands.c:lxc_cmd:511 - Connection refused - Command “get_state” failed to connect command socket
lxc 20211018110444.197 TRACE commands - commands.c:lxc_cmd:511 - Connection refused - Command “get_state” failed to connect command socke
