I have a debian server, with a static ip adress defined in /etc/network/interfaces
I would like the lxd containers to be ssh-able over the host network.
I used these
lxc profile device set default eth0 parent eth0
lxc profile device set default eth0 nictype macvlan
This worked when I didn’t have a static ip adress for the host, however I seem to be stuck when I want a static ip adress for the host…
Any help? Where to look? The solution lies in setting up a proper bridge and applying that on the containers, however this is were I lack knowledge, but also a bit of documentation, I’m afraid. Maybe I just didn’t find it…
In the last few days I have been seeking answers to the same questions. It does seem a black art. LXD versions have evolved so much over the past few years, that googling for help may end up with out of date information.
But to answer, I think we need to know what version of LXD and LXC you are using? Run following and post output.
The main limitation of macvlan is that host to container communication isn’t possible.
That’s separate from any considering about static/dynamic networking, it’s just a limitation of the kernel macvlan driver.
In your case, your best bet may be to configure bridge networking in /etc/network/interfaces of your host, something like this:
This requires the “bridge-utils” package be installed. With the above adapted for your network (effectively replacing “eth0” for “br0” and adding that “bridge-ports” line), you should end up with your system back online and connected through br0.
You can then set nictype=bridged parent=br0 in the default profile, this should get you the same behavior as macvlan except that host to container communication will work now.
