I need to specific static ip addresses for some containers using the sr-iov config https://lxd.readthedocs.io/en/latest/instances/#nic-sriov
Ubuntu 20.04 does support it on the OS level via netplan https://netplan.io/examples/#configuring-sr-iov-virtual-functions. I’m using Ubuntu 20.04 as the host and in the containers.
Is there some onfiguration I can do within the container to get a static ip? Or will I be able to specify an ip address in the lxd config in the future? Having to use DHCP makes things a bit difficult.
