I’m new using LXD / LXC and I want to automate some tasks with ansible.
To do that I’ve create an yaml file to init LXC with the command
lxd init --preseed < /tmp/lxcInitFile.yaml (I’ve retrieved the yaml file after a manual installation)
config: {}
networks:
- config:
ipv4.address: auto
#ipv4.nat: "true"
ipv6.address: none
type: ""
storage_pools:
- config:
driver: zfs
- config: {}
network: custom0
pool: default
cluster: null
My problem is that with this method, a default pool is not created and when I want to launch a container, it fails.
root@jekes:~# zpool status
no pools available
If someone have an idea, it will be great.
Thanks
