just updated my LXD to 5.6 and I am trying to create Minio storage bucket. Not sure if anything special is needed on non-snap versions of LXD but I am getting following error:
No, the fact that we’re using minio is an implementation detail here.
What we actually offer is an S3 compatible API which can be used with the like of s3cmd or any application used to storing and fetching data from S3 buckets.
There’s a better error in the logs. The api request fails due to timing out connection due to minio not starting. I’ll see if I can improve the error but it was somewhat decoupled internally.
Additional question: is it possible to somehow add “proper” SSL certificate and/or domain to S3 endpoint ? So instead https://my.ip.addr:port to have something with domain and proper SSL cert ? Some clients that do not have “clear” way of ignoring SSL/TLS check would benefit from this.
