I am running lxd 5.9 on debian 11.0 host machine. While creating a container, it is taking long time to create (seems like stuck).
root@monitor:~# lxc launch images:debian/bullseye test
Creating test
can you help me on this ?
Thanks
Creating test
Thanks
Could be a network issue if it’s the first time a particular image is used.
You can check what’s going on with lxc operation list
but there’s a good chance you’re stuck in image download.
@stgraber thanks for the fast response
the image is already downloaded on the host
root@monitor:~# lxc image list
| ALIAS | FINGERPRINT | PUBLIC | DESCRIPTION | ARCHITECTURE | TYPE | SIZE | UPLOAD DATE |
| | 93d985be253b | no | Debian bullseye amd64 (20230104_05:25) | x86_64 | CONTAINER | 83.54MB | Jan 5, 2023 at 3:29am (UTC) |
it taking about 3-4mins to create and delete a container.
also checking lxc operation list
, seems it shows normal
root@monitor:~# lxc operation list
| ID | TYPE | DESCRIPTION | STATUS | CANCELABLE | CREATED |
| 2e3e71df-2b7c-4d40-a7c7-e3714b7009bc | TASK | Creating instance | RUNNING | NO | 2023/01/05 14:07 UTC |
| 10625d7a-5475-416c-8ba5-6565790d4233 | TASK | Stopping instance | RUNNING | NO | 2023/01/05 14:12 UTC |
Is there any method to find and troubleshoot the issue?
Thanks
Hmm, I’d probably look into the usual suspects:
dmesg
for anything kernel relatedps fauxww
and top
to see what’s using CPU/memory when things are slowYou can also run lxc monitor --pretty
in another terminal which will get you LXD debugging logs.
This may give more details as far as what’s taking so long.
Benchmark your system first to see if everything checks out (what filesystem are you using?)
#Sequential write test
sync;fio --randrepeat=1 --ioengine=libaio --direct=1 --name=test --filename=test --bs=4M --size=4G --readwrite=write --ramp_time=4 numjobs=$(nproc)
#Sequential Read test
sync;fio --randrepeat=1 --ioengine=libaio --direct=1 --name=test --filename=test --bs=4M --size=4G --readwrite=read --ramp_time=4 numjobs=$(nproc)
Run an iperf test as well while you’re at it (iperf not iperf3)
iperf -s
iperf -c localhost -P $(nproc)
then use lxd-benchmarking tool
