using proxy device with nat=true for both TCP and UDP, and only TCP and UDP, do i need to have 2
$ct-$name-$port hostport-$ct-$name-$port proxy connect="$ip:$port" listen="192.168.0.x:$port" nat="true"
one per protocol?
one per protocol?
You will need one per protocol.
E.g.
lxc config device add c1 p1 proxy listen=tcp:n.n.n.n:80 connect=tcp:n.n.n.n:80 nat=true
