I’ve successfully set up port forwarding on the host. Because I can do netcat nc -l 8333
on the server in the container on the port and nc -v 151.35.26.44 8333
on my desktop and send messages successfully.
description: "coins.js"
config: {}
ports:
- description: "btc"
protocol: tcp
listen_port: "8333"
target_address: 10.103.26.59
- description: "doge"
protocol: tcp
listen_port: "22556"
target_address: 10.103.26.27
listen_address: 151.35.26.44
But it seems like the container is missing instruction to use the listen_address
I can see this when I run bitcoin-cli inside the container and view the output of the command getpeerinfo
because each peer shows "addrlocal" : "67.14.11.21:52790"
which is my websites main ip not the listen address. It should be listen_address:random_port
instead.
How do I instruct the container to use the listen address instead of the main ip?
