@freeekanayaka submitted a potential fix for this last week which is being rolled out to LXD 3.6 snap users, if that works, weβll put it in the queue for LXD 3.0.3.
since I post this, lxc command stuck forever and I canβt maintain lxd cluster.
today, I need change something, so restart one lxd node, it failed with below log:
11ζ 06 15:59:27 dxc4 lxd[1277]: lvl=warn msg="Failed to update heartbeat: failed to begin transaction: sql: database is closed" t=2018-11-06T15:59:27+0800
11ζ 06 15:59:27 dxc4 lxd[1277]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: sql: database is closed" t=2018-11-06T15:59:27+0800
11ζ 06 15:59:27 dxc4 lxd[1277]: err="failed to begin transaction: sql: database is closed" lvl=eror msg="Unable to fetch cluster configuration" t=2018-11-06T15:59:27+0800
11ζ 06 15:59:27 dxc4 lxd[1277]: 2018/11/06 15:59:27 http: multiple response.WriteHeader calls
11ζ 06 15:59:28 dxc4 lxd[1277]: lvl=warn msg="Raft: Unable to get address for server id 3, using fallback address 10.2.1.202:8443: failed to begin transaction: sql: database is closed" t=2018-11-06T15:59:28+0800
11ζ 06 15:59:28 dxc4 lxd[1277]: lvl=warn msg="Raft: Unable to get address for server id 1, using fallback address 0: failed to begin transaction: sql: database is closed" t=2018-11-06T15:59:28+0800
11ζ 06 15:59:28 dxc4 lxd[1277]: lvl=warn msg="Raft: Unable to get address for server id 2, using fallback address 10.2.1.235:8443: failed to begin transaction: sql: database is closed" t=2018-11-06T15:59:28+0800
the other node logs
11ζ 06 16:18:25 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:18:25+0800
11ζ 06 16:18:26 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:18:26+0800
11ζ 06 16:18:27 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:18:27+0800
11ζ 06 16:19:52 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:19:52+0800
11ζ 06 16:29:52 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:29:52+0800
11ζ 06 16:39:52 dxc3 lxd[5244]: lvl=warn msg="Failed to get current cluster nodes: failed to begin transaction: cannot start a transaction within a transaction" t=2018-11-06T16:39:52+0800
