Hi all,
I will start this post by describing what my attempt is, as well as describe my environment.
I read:
https://linuxcontainers.org/lxd/docs/latest/reference/devices_disk/
https://linuxcontainers.org/lxd/docs/latest/howto/storage_volumes/
https://linuxcontainers.org/lxd/docs/latest/reference/devices_unix_block/
I have a 3 nodes lxd cluster with ceph storage pool intialised via microceph and set up in lxd the following way:
mother@infra1:~$ lxc storage create remote ceph --target infra1
Storage pool remote pending on member infra1
mother@infra1:~$ lxc storage create remote ceph --target infra2
Storage pool remote pending on member infra2
mother@infra1:~$ lxc storage create remote ceph --target infra3
Storage pool remote pending on member infra3
mother@infra1:~$ lxc storage create remote ceph ceph.cluster_name=ceph ceph.osd.pool_name=lxd
Storage pool remote created
mother@infra1:~$ lxc staorage ls
Error: unknown command "staorage" for "lxc"
Did you mean this?
storage
mother@infra1:~$ lxc storage ls
| NAME | DRIVER | DESCRIPTION | USED BY | STATE |
| local | zfs | | 1 | CREATED |
| remote | ceph | | 0 | CREATED |
I would like to add a custom storage volume to one of my containers/vms in that pool in a custom path.
I am trying to start juju openstack charm and ideally would like to add a block device to a container with ceph osd installed so that ceph can use this block device(I read unix-block documentation but I do not have the ceph custom volume path I could use as source)
I do not mind having ceph osd run as vms if the first option is currently impossible. I assume one has to create a custom volume with --type block and then attach it to the vm( as described in how to manage storage). I also assume that lxc config device add
and lxc storage volume attach
are doing basically the same(if not @tomp please correct me )
Here is what I tried so far:
mother@infra1:~$ lxc storage volume create remote cephdrive size=55GB
Storage volume cephdrive created
mother@infra1:~$ lxc config device add juju-51f46b-23 cephdrive disk pool=remote source=cephdrive path=/srv/osd
Error: Failed to start device "cephdrive": Cannot attach directory while instance is running
mother@infra1:~$ lxc stop juju-51f46b-23
Device cephdrive added to juju-51f46b-23
mother@infra1:~$ lxc start juju-51f46b-23
mother@infra1:~$ lxc config device remove juju-51f46b-23 cephdrive
Device cephdrive removed from juju-51f46b-23
mother@infra1:~$ lxc storage volume delete remote cephdrive
Storage volume cephdrive deleted
mother@infra1:~$ lxc storage volume create remote cephdrive size=60GB --type block
mother@infra1:~$ lxc storage volume attach remote cephdrive juju-51f46b-23 ceph-block
Error: Failed add validation for device "cephdrive": Custom block volumes cannot have a path defined
Error: Failed setting up device via monitor: Failed adding block device for disk device "cephdrive": Failed adding block device: error reading header from custom_juju_cephdrive.block: No such file or directory
Try `lxc info --show-log juju-51f46b-23` for more info
mother@infra1:~$ lxc config device add juju-51f46b-23 cephdrive_man disk source=ceph:remote/cephdrive ceph.user_name=lxd ceph.cluster_name=lxd /srv/osd
Error: No value found in "/srv/osd"
Device cephdrive_man added to juju-51f46b-23
Error: Failed setting up disk device "cephdrive_man": Failed to open "/etc/ceph/lxd.conf": open /etc/ceph/lxd.conf: no such file or directory
mother@infra1:~$ lxc config device add juju-51f46b-23 cephdrive disk source=ceph:remote/cephdrive
Error: Failed setting up device via monitor: Failed adding block device for disk device "cephdrive": Failed adding block device: error opening pool remote: No such file or directory
Am I doing something wrong?
Currently the only way I am able to add the disk and start the machine is to create custom storage as filesystem not block but it does not meet the osd charm requirements.
@stgraber is it related to the specification of microceph snap?
As always thank you very much for any piece of advice and the patience
Mateusz
