Tryin pnetlab on container (using LXD)
my friends, i”m trying pnetlab on container instead VM aiming more performance but for some reason i”m having a issue what just happening with a container.
pnetlab open and looks working except dockers, but when i install it some problems with apt start, i need help to solve it.
root@pnetlab:~# apt upgrade
Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 1122 (apt)
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following security updates require Ubuntu Pro with ‘esm-infra’ enabled:
libsoup-gnome2.4-1 php7.4-gd php7.4-cli libopenjp2-7 bind9-dnsutils
cloud-init libcups2 jq openssl libblockdev-swap2 sntp libgdk-pixbuf2.0-0
libssh-4 libpython3.8-minimal libctf-nobfd0 git-man libsystemd0 php7.4-json
mysql-client-8.0 gcc-10-base gstreamer1.0-plugins-good libgs9
python2.7-minimal lib32gcc-s1 mysql-server libsqlite3-0 mysql-server-8.0
python3-urllib3 binutils php7.4-curl bind9-host php7.4 libitm1 libjq1 sudo
python2.7 libpython3.8 python3.8 python-apt-common open-vm-tools git
libblockdev-crypto2 udev gstreamer1.0-plugins-base libblockdev-loop2
libquadmath0 libblockdev-fs2 php7.4-sqlite3 libblockdev-part2 apache2-data
openjdk-11-jre-headless python3-requests libgstreamer-plugins-good1.0-0
libudev1 libsoup2.4-1 php7.4-opcache ntp binutils-x86-64-linux-gnu ntpdate
sqlite3 lib32gcc1 php7.4-xml libtiff5 udisks2 libtsan0 php7.4-zip libubsan1
mysql-client-core-8.0 python3.8-minimal openjdk-11-jdk systemd-sysv
libblockdev2 php7.4-mysql openjdk-11-jre libpam-systemd
libgstreamer-plugins-base1.0-0 php7.4-mbstring php7.4-readline
gstreamer1.0-x ghostscript liblsan0 systemd libgomp1 libgdk-pixbuf2.0-bin
libssh-gcrypt-4 libblockdev-utils2 libgdk-pixbuf2.0-common libnss-systemd
libgs9-common binutils-common libblockdev-part-err2 libgcc-s1 libxml2
libbinutils libpython2.7-minimal libpython3.8-stdlib libgnutls30 apache2-bin
libudisks2-0 php7.4-common libatomic1 libssl1.1 libcc1-0 libpython2.7-stdlib
apache2 libstdc++6 apache2-utils openjdk-11-jdk-headless
libapache2-mod-php7.4 bind9-libs python3-apt libctf0 libxslt1.1
mysql-server-core-8.0 libpng16-16
Learn more about Ubuntu Pro at Ubuntu Pro | Ubuntu
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up pnetlab (6.0.0-103) …
cat: /etc/udhcpd.init: No such file or directory
/var/lib/dpkg/info/pnetlab.postinst: line 72: /sys/fs/cgroup/cpu/release_agent: No such file or directory
/var/lib/dpkg/info/pnetlab.postinst: line 73: /sys/fs/cgroup/memory/release_agent: No such file or directory
127.0.0.127 xml.cisco.com
Tuning nat interface… Creating MySQL backup done
ln: failed to create symbolic link ‘/usr/local/sbin/mode’: File exists
Checking SSL… done
Checking MySQL users table for quotas… Platform detection and tuning flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip rdpid overflow_recov succor smca sev sev_es
/usr/sbin/grub-probe: error: failed to get canonical path of `/dev/sdb2’.
dpkg: error processing package pnetlab (–configure):
installed pnetlab package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
pnetlab
E: Sub-process /usr/bin/dpkg returned an error code (1)
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
