ubuntu 20.04 lxd 4.6
lxc config device add mytest eth0 nic nictype=routed parent=eno1 ipv4.address=192.168.20.31
lxc start mytest
all works fine after little netplan config edit
lxc stop mytest
lxc config device add mytest eth1 nic nictype=routed parent=eno1 ipv4.address=192.168.20.32
lxc start mytest
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart mytest /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/mytest/lxc.conf:
Try lxc info --show-log mytest
for more info
In logfile:
lxc mytest 20200927174100.546 ERROR network - network.c:lxc_network_setup_in_child_namespaces_common:3464 - File exists - Failed to add ipv4 dest “169.254.0.1” for network device “eth1”
lxc mytest 20200927174100.546 ERROR network - network.c:lxc_setup_network_in_child_namespaces:3528 - File exists - Failed to setup netdev
lxc mytest 20200927174100.546 ERROR conf - conf.c:lxc_setup:3218 - Failed to setup network
lxc mytest 20200927174100.546 ERROR start - start.c:do_start:1224 - Failed to setup container “mytest”
lxc mytest 20200927174100.546 ERROR sync - sync.c:__sync_wait:41 - An error occurred in another process (expected sequence number 5)
lxc mytest 20200927174100.546 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:850 - Received container state “ABORTING” instead of “RUNNING”
lxc mytest 20200927174100.547 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container “mytest”
What’s my mistake?
