I have a lxd container on local ip 192.168.69.37 and I want to block it from accessing the local lan, to
protect others on the lan, should there be a breach of security inside the container.
I’ve studied a few links such as these
but I still seem unable to get this to do what I want. I don’t want to rely on iptables set within the container because if it’s breached then they can be removed. Basically I want to sandbox the container but have it still able to access the web.
$ cat /etc/lsb*
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Ubuntu 22.04.1 LTS"
$ lxd --version
5.5
$ ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.69.18 netmask 255.255.255.0 broadcast 192.168.69.255
inet6 fe80::eade:aad2:9662:ba73 prefixlen 64 scopeid 0x20<link>
ether a0:48:1c:76:9f:7b txqueuelen 1000 (Ethernet)
RX packets 208694899 bytes 100888823720 (100.8 GB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 60843646 bytes 88925493677 (88.9 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xf7c00000-f7c20000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 7846 bytes 857058 (857.0 KB)
TX packets 7846 bytes 857058 (857.0 KB)
lxdbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 10.126.130.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fd42:792b:ccc:e513::1 prefixlen 64 scopeid 0x0<global>
ether 00:16:3e:c3:0b:8b txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
$ sudo ufw deny from 192.168.69.37 to 192.168.0.0/16
Rule added
$ sudo ufw reload
Firewall reloaded
$ sudo ufw status
Status: active
To Action From
22 ALLOW Anywhere
8443 ALLOW Anywhere
192.168.0.0/16 DENY 192.168.69.37
22 (v6) ALLOW Anywhere (v6)
8443 (v6) ALLOW Anywhere (v6)
Going inside the container…
$ lxc exec OBA-CAMS -- bash
# ssh 192.168.69.28 -l rich
rich@192.168.69.28's password:
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.4.0-125-generic x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
0 updates can be applied immediately.
Last login: Fri Aug 26 11:12:14 2022
rich@rich:~$ exit
logout
Connection to 192.168.69.28 closed.
# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.69.37 netmask 255.255.255.0 broadcast 192.168.69.255
inet6 fe80::216:3eff:fec8:ddae prefixlen 64 scopeid 0x20<link>
ether 00:16:3e:c8:dd:ae txqueuelen 1000 (Ethernet)
RX packets 173870606 bytes 91602648327 (91.6 GB)
TX packets 487070 bytes 49353764 (49.3 MB)
RX packets 78699850 bytes 83517012553 (83.5 GB)
TX packets 78699850 bytes 83517012553 (83.5 GB)
After making the connection I can’t see anything helpful in /var/log/ufw.log
