Unable to Create Container on lxc
Title:
Error: sql: transaction has already been committed or rolled back during instance creation
Description:
While attempting to launch a new instance using the following command:
lxc launch ubuntu:24.04 test --profile profile-STG-2
I encountered the following error:
Error: Failed instance creation: Fetch project database object: Failed to fetch from "projects" table:
Failed to fetch from "projects" table: Failed to fetch from "projects" table:
LXD Version:
snap list lxd
Name  Version         Rev    Tracking     Publisher   Notes
lxd   5.21.3-c5ae129  33110  5.21/stable  canonical✓  in-cohort
Logs:
The following warnings are repeatedly appearing in /var/snap/lxd/common/lxd/logs/lxd.log:
time="2025-10-08T12:15:32+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: ... sql: transaction has already been committed or rolled back)"
time="2025-10-08T12:15:32+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T12:24:28+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T12:33:19+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T12:42:48+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T12:48:58+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T12:54:19+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
time="2025-10-08T17:41:08+05:00" level=warning msg="Failed to rollback transaction after error (Fetch project database object: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: Failed to fetch from \"projects\" table: sql: transaction has already been committed or rolled back): sql: transaction has already been committed or rolled back"
These warnings continue to repeat at different timestamps, indicating a possible database transaction issue in LXD.
Request:
Please advise how to resolve or recover from this database-related error. Should I perform a database restore, or is there a known fix for this issue in version 5.21.3?
I am sorry. We don’t provide support for LXD on this forum. You might have better luck contacting Canonical.
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
