I smell a bug, but I wanna double check. I posted this in chat, but I suspect this is going to be more involved.
I have an Incus test cluster, 3 nodes, each node has 1 drive (btrfs), 1 NIC. I’m not using ceph or ovn.
I’m playing around with Incus and TerraformOpenTofu, and it seems that twiddling features.networks on a project can make it undeletable.
I don’t see any resources in the UI, but if I try to delete it, it says Failed loading network: Failed to connect to OVN: Failed to connect to OVS: Failed to connect to OVS: Failed to connect to OVS: failed to connect to unix:/run/openvswitch/db.sock: failed to open connection: dial unix /run/openvswitch/db.sock: connect: no such file or directory
$ incus project show forge
features.images: "false"
features.networks: "true"
features.networks.zones: "true"
features.profiles: "false"
features.storage.buckets: "true"
features.storage.volumes: "true"
restricted: "false"
- /1.0/networks/default?project=forge
$ incus --project=forge network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
I do have a network default in my default project (as opposed to my default network, which is incusbr0). But deleting that network doesn’t change either of the above commands or allow the project to be deleted.
At this point, I have:
$ incus network list --all-projects
| PROJECT | NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| default | enx9cbf0d0016f8 | physical | NO | | | | 1 | |
| default | incusbr0 | bridge | YES | 10.187.122.1/24 | fd42:a4e7:10cd:d9a9::1/64 | | 3 | CREATED |
| default | ingress | bridge | YES | 10.187.164.1/24 | fd42:596:cb79:eebd::1/64 | | 0 | CREATED |
| default | lo | loopback | NO | | | | 0 | |
| default | public | macvlan | YES | | | | 0 | CREATED |
restricted: "false"
