This is under LXD 3.18.
The behavior I’m seeing is that if I try to publish a container using a remote spec that resolves to the host I’m currently working on, the target image is not registered. It doesn’t fail. It tells me it s completes but a lxc image list doesn’t contain the expected image.
Here’s the setup:
- I log onto my LXC server
- I create a remote named test as follows: lxc remote add test unix://. (Note I’ve also tried it with the IP of the host).
- I run the command: lxc publish test:my_container --alias testimage
LXC churns away, completes successfully but a lxc image list does not show testimage.
-steve
