UPDATE #1
I was able to get stable eth0 / IP for each container by switching to bridged network type with lxc config device add c2 eth0 nic nictype=bridged parent=br0 name=eth0
From my searching, I thought I would be able to use an OVS internal port as a physical nic type for a container for better performance vs veth. Does anyone have any insight into that or what about the original setup I was doing incorrectly? Thanks!
URL References for what I was originally trying to accomplish with LXC / OVS internal ports:
https://arthurchiao.github.io/blog/ovs-deep-dive-6-internal-port/ (Section 3 & 4)
https://www.opencloudblog.com/?p=66
https://www.opencloudblog.com/?p=96 (Performance of veth vs internal port)
I’m working on setting up a testing environment with Virtualbox/Vagrant running Ubuntu 18.04 as the LXC host (not ideal as there are so many layers, but don’t have a better solution at the moment).
I’ve got it working 90% of the way, but having an issue when starting another container on the host, the previous container loses its IP and eth0 is no longer shown when running ifconfig on that container and visa versa when starting the 1st container, 2nd container loses its ip / eth0.
The goal is to have the containers have their own (static) IP on my LAN. I’ve got this working when only one container is running.
Ubuntu 18.04 Host Network Setup:
- Bridge named br0 setup with:
ovs-vsctl add-br br0
- Bridge is connected to ethernet port enp0s9 with:
ovs-vsctl add-port br0 enp0s9
- No IP is assigned to br0 or enp0s9 as the host is managed via another nic interface
- Ports for the containers are added to the br0 interface with:
ovs-vsctl add-port br0 vport1 -- set Interface vport1 type=internal
andovs-vsctl add-port br0 vport2 -- set Interface vport2 type=internal
Container setup (c1 and c2):
- Containers are created with
lxc init ubuntu:18.04 c1 -p t1
(t1 profile listed below) - Each configured to grab static IP from LAN router via netplan (file contents pasted below)
- eth0 is added to the containers with:
lxc config device add c1 eth0 nic nictype=physical parent=vport1 name=eth0
andlxc config device add c2 eth0 nic nictype=physical parent=vport2 name=eth0
What happens:
- Launching c1 causes it to grab its static IP (router also shows it in its client list)
- c1 is able to access internet and be accessed over LAN (installed nginx to test) which is the expected result
- When c2 is launched, c1 loses its IP and eth0 in container (ifconfig no longer shows eth0 in the container)
- c2 shows running with an IP but isn’t accessible either, lxc list shows no IP for c1 anymore
- Have to stop both containers and start just one (c1 or c2) for it to then to grab it’s IP and be accessible, but both cannot run at the same time as it causes the other to lose IP and both will not have network access either
Thank you in advance!!!
Below I’ve pasted expanded details for container and host config:
t1 profile info
lxc profile show t1
limits.cpu: "1"
limits.memory: 512MB
security.devlxd: "false"
security.idmap.isolated: "true"
pool: default
- /1.0/containers/c1
- /1.0/containers/c2
c1 config show expanded
lxc config show c1 --expanded
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20190918)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20190918"
image.type: squashfs
image.version: "18.04"
limits.cpu: "1"
volatile.base_image: 9ff5784302bfd6d556ac4c4c1176a37e86d89ac4d1aced14d9388919fa58bee8
volatile.eth0.host_name: vport1
volatile.eth0.last_state.created: "false"
volatile.eth0.last_state.hwaddr: 02:cf:64:d5:55:72
volatile.eth0.last_state.mtu: "1500"
volatile.idmap.base: "1065536"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1065536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1065536,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1065536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1065536,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1065536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1065536,"Nsid":0,"Maprange":65536}]'
nictype: physical
parent: vport1
pool: default
- t1
c2 config show expanded
lxc config show c2 --expanded
image.os: ubuntu
limits.cpu: "1"
volatile.idmap.base: "1131072"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1131072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1131072,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1131072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1131072,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1131072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1131072,"Nsid":0,"Maprange":65536}]'
nictype: physical
parent: vport2
pool: default
- t1
I noticed that c1 has extra volatile fields, however I’m not for sure what they are for or if they are causing an issue?
lxc list when one container is running (and working with network access)
| c1 | RUNNING | 192.168.1.113 (eth0) | | PERSISTENT | 0 |
| c2 | STOPPED | | | PERSISTENT | 0 |
lxc list when the 2nd container is started and network for both is not working
| c1 | RUNNING | | | PERSISTENT | 0 |
| c2 | RUNNING | 192.168.1.114 (eth0) | | PERSISTENT | 0 |
ifconfig on c1 showing when it’s working vs when it stops
Working:
root@c1:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.113 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::cf:64ff:fed5:5572 prefixlen 64 scopeid 0x20<link>
ether 02:cf:64:d5:55:72 txqueuelen 1000 (Ethernet)
RX packets 865 bytes 85073 (85.0 KB)
RX errors 0 dropped 617 overruns 0 frame 0
TX packets 31 bytes 2781 (2.7 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 4 bytes 280 (280.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 4 bytes 280 (280.0 B)
Not working:
root@c1:~# ifconfig
Contents of /etc/netplan/50-cloud-init.yaml
C1:
network:
version: 2
ethernets:
dhcp4: no
addresses: [192.168.1.113/24]
gateway4: 192.168.1.254
nameservers:
addresses: [8.8.8.8]
C2:
network:
version: 2
ethernets:
dhcp4: no
addresses: [192.168.1.114/24]
nameservers:
Host networking output:
sudo ovs-vsctl show
5d5744dd-4eb4-4b77-b206-c3cc1cabc9cd
Bridge "br0"
Port "vport2"
Interface "vport2"
type: internal
Port "enp0s9"
Interface "enp0s9"
Port "vport1"
Interface "vport1"
type: internal
Port "br0"
Interface "br0"
type: internal
ovs_version: "2.9.2"
ifconfig on host
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::a00:27ff:feca:2ca5 prefixlen 64 scopeid 0x20<link>
ether 08:00:27:ca:2c:a5 txqueuelen 1000 (Ethernet)
RX packets 18066 bytes 1861492 (1.8 MB)
RX errors 0 dropped 8499 overruns 0 frame 0
TX packets 161 bytes 13990 (13.9 KB)
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.2.15 netmask 255.255.255.0 broadcast 10.0.2.255
inet6 fe80::27:29ff:fe89:289f prefixlen 64 scopeid 0x20<link>
ether 02:27:29:89:28:9f txqueuelen 1000 (Ethernet)
RX packets 15038 bytes 3013562 (3.0 MB)
TX packets 8822 bytes 843196 (843.1 KB)
enp0s8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.33.10 netmask 255.255.255.0 broadcast 192.168.33.255
inet6 fe80::a00:27ff:fe73:a60e prefixlen 64 scopeid 0x20<link>
ether 08:00:27:73:a6:0e txqueuelen 1000 (Ethernet)
RX packets 207 bytes 18054 (18.0 KB)
TX packets 20 bytes 1616 (1.6 KB)
enp0s9: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 297403 bytes 205203712 (205.2 MB)
RX errors 0 dropped 38 overruns 0 frame 0
TX packets 24505 bytes 1999936 (1.9 MB)
RX packets 154 bytes 14788 (14.7 KB)
TX packets 154 bytes 14788 (14.7 KB)
lxdbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.182.32.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fe80::3819:95ff:fe36:ee2d prefixlen 64 scopeid 0x20<link>
inet6 fd42:ee98:50a6:f88f::1 prefixlen 64 scopeid 0x0<global>
ether 3a:19:95:36:ee:2d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 16 bytes 1972 (1.9 KB)
Container’s route info:
When working:
root@c1:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default _gateway 0.0.0.0 UG 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
When not working:
root@c1:~# route
default 192.168.1.254 0.0.0.0 UG 0 0 0 eth0
Where _gateway resolves too:
root@c1:~# nslookup _gateway
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 192.168.1.254
** server can't find _gateway: NXDOMAIN
