Connections received on /postgresql.sock on the colima VM will be proxied to /run/postgresql.sock in the container.
If you use bind=instance then incus will create a socket inside the instance, listen on that, and will proxy to a socket on the host.
In both cases, it’s up to you to create the target socket (i.e. the one which will receive the proxied connection). If it doesn’t exist, then the connection will fail. In my example above, I hadn’t installed postgres inside the container. If I attempt a connection there’s nowhere for it to go, so it’s dropped on the floor.
brian@colima:/Users/brian$ sudo nc -U /postgresql.sock
brian@colima:/Users/brian$ echo $?
0
brian@colima:/Users/brian$ sudo tail -2 /var/log/incus/test1/proxy.socket-psql.log
Warning: Failed to connect to target: dial unix /run/postgresql.sock: connect: no such file or directory
Warning: Failed to prepare new listener instance: dial unix /run/postgresql.sock: connect: no such file or directory
With two containers, A and B:
If container A is running postgres, it will already have a postgres listening socket
Create a proxy device on container A with “bind=host” to accept inbound connections
If container B is running psql or an application that wants to talk to postgres, create a proxy device with “bind=instance” to create a socket inside the container; set the connect destination to the path on the host which was created by the proxy device
Alternatively you could use TCP/IP directly between the containers, as long as postgres is set up to allow it (hba.conf)
