Disclosure: I don’t fully understand ZFS!
I was just going to check what was consuming space in some of my containers. I tried running ncdu
from the host against the container mountpoints as shown in zfs list
(i.e. sudo ncdu /var/snap/lxd/common/lxd/storage-pools/lxd/containers/web-server
) but whilst all the folders I expected were shown, the sizes don’t align with what ZFS reports:
ncdu 1.11 ~ Use the arrow keys to navigate, press ? for help
--- /var/snap/lxd/common/lxd/storage-pools/lxd --------------------------------------------------------------------------------------------------------------------------------------------------------------
52.0 KiB [##########] /containers
16.0 KiB [### ] /containers-snapshots
8.0 KiB [# ] /images
e 4.0 KiB [ ] /virtual-machines-snapshots
e 4.0 KiB [ ] /custom-snapshots
Within ncdu
, I can drill down all the way into what I would expect to be the root of the container but ncdu
shows an empty folder.
I then found some other info, that under snap
the container mounts could be found under /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pools/<pool-name>/containers
but that was exactly the same issue.
Any hints on how I might be able to drill down into this?
Cheers,
Whytey
