I get the message listed in the subject line in a KDE konsole shell running on Fedora 44. I’m running and a makefile in the shell.
Any ideas how to suppress this message?
Glycin uses unprivileged user namespaces. Linux containers also use unprivileged user namespaces. Therefore, if you want an application running inside a Linux container to use unprivileged user namespaces, you need to enable nesting. By enabling nesting, software that runs in a container can use also unprivileged user namespaces. Because by default they cannot do so.
How do I enable nesting?
BTW, this seems only to happen with a Fedora 44 container. I’m not seeing the same message on a similarly configured container running Alma 9.
You can give it a go and check whether it fixes the issue. Then restart the container.
incus config set <container_name> security.nesting=true
Setting security.nesting=true causes a couple problems: NFS mounts no longer work. IPV6, which was previously blocked, is now active. I can’t tell if this affected the warning message or not.
Can you provide some background information?
What’s the Linux distribution of the host, which Incus version you are running on the host, which image goes in the unprivileged container (for example, images:fedora/43/cloud), and what instructions did you use to get the GUI running the the unprivileged container.
Host is Ubuntu 24.04.4. Incus 7.5.1. I believe the image was images:fedora/44/x86_64. Is there a way to tell from the configuration? I installed KDE using dnf.
