Way to mount the .bin file created by incus export for read-only review on a running incus server?
Question: What is the best way to mount the .bin file that’s created by incus export for read-only review on a running incus server so it doesn’t interfere with the existing running instances?
Background:
I have a linux virtual machine on an Incus server that has a block device for it’s hard drive.
$zfs list
default/virtual-machines                      111G  3.37T    24K  legacy
default/virtual-machines/myvirtual1          10.1M   490M  10.1M  legacy
default/virtual-machines/myvirtual1.block     102G  3.37T   102G  -
I run incus exportnightly and have many backups where the tar.gz file for this VM has files in it
index.yaml virtual-machine.bin virtual-machine-config.bin
$ file virtual-machine.bin
virtual-machine.bin: ZFS snapshot (little-endian machine),
version 17301505, type: ZVOL, destination GUID: REDACTED,
$ file virtual-machine-config.bin
virtual-machine-config.bin: ZFS snapshot (little-endian machine),
version 17301521, type: ZFS, destination GUID: REDACTED,
I want to be able to mount the block .bin device on the incus server and and move a ton of files in that mount to a new container that will be setup as a regular incus container in default/containers/Container2
The reason why I’m trying it this way is because the simple rsync between running instances VM myvirtual1 and Container2 was causing iostat issues, but I can think of other reasons one might want to mount an old .bin file too (Disaster recovery, forensics, real-time change monitoring, etc, etc.)
I’m new to zfs, so forgive this newbie question. I don’t want to mess up my existing incus zpools or use up a ton of space importing a large filesystem as a duplicate.
To repeat the above question
I’ve looked up recommended methods and there seem to be two ways to do this
(1) stream the .bin file to a new temporary pool:
#create sparse file
truncate -s 50G /tmp/zfs_temp.raw
#point pool to blank file
zpool create temprecovery /tmp/zfs_temp.raw
#stream data into zpool
zfs recv temprecovery/disk < virtual-machine.bin
#find loop
FOOLOOP=$(kpartx -av /dev/zvol/temprecovery/disk)
mkdir -p /mnt/vm_files
mount /dev/mapper/$FOOLOOP /mnt/vm_files
#when done ... remove it all
umount /mnt/vm_files
kpartx -dv /dev/zvol/temprecovery/disk
zpool destroy temprecovery
rm /tmp/zfs_temp.raw
(2) Attach the old file to a loop device (apparently this doesn’t work since the .bin files are zfs - streams)
—BEGIN IGNORE THIS PART—
# Create loop device
losetup /dev/loop20 /path/to/virtual-machine.bin
#import that block device
zpool import -d /dev/loop20 -o readonly=on -o altroot=/mnt/recovery mypool
zpool status
zfs list
# see if it is already mounted in /mnt/recovery
# if not mounted
zfs mount mypool/MYDATA  #where MYDATA is what shows up under
-–END IGNORE THIS PART—
(2) Stream directly to a new volume in the existing default pool
# 1. Receive stream into new
zfs receive default/recovery-disk < virtual-machine.bin
# 2. Map partitions
FOOLOOP=$(kpartx -av /dev/zvol/default/recovery-disk)
# 3. Mount the target partition
mkdir -p /mnt/recovery_os
mount /dev/mapper/"$FOOLOOP" /mnt/recovery_os
Thanks!
