Hi.
In the new lxd container, I got an error that the package could not be installed due to lack of space.
I’m using /dev/loop0 as a storage pool.
53GB out of 64GB is used, what is it used for? can’t I clear it?
% df -h
devtmpfs 4.0M 0 4.0M 0% /dev
tmpfs 3.9G 12K 3.9G 1% /dev/shm
tmpfs 1.6G 9.2M 1.6G 1% /run
/dev/mapper/main-root 457G 216G 218G 50% /
tmpfs 3.9G 8.0K 3.9G 1% /tmp
/dev/sda1 356M 162M 195M 46% /boot
tmpfs 783M 44K 783M 1% /run/user/120
tmpfs 100K 0 100K 0% /var/lib/lxd/shmounts
tmpfs 100K 0 100K 0% /var/lib/lxd/devlxd
tmpfs 783M 28K 783M 1% /run/user/1337
/dev/loop0 64G 53G 8.6G 86% /var/lib/lxd/storage-pools/default
no image.
% sudo lxc image list
| ALIAS | FINGERPRINT | PUBLIC | DESCRIPTION | ARCHITECTURE | TYPE | SIZE | UPLOAD DATE |
one storage pool. name default
% sudo lxc storage list
| default | btrfs | f7bba9af-297c-4e88-952d-06f960ccb4bc | | 1 | CREATED |
detail.
% sudo lxc storage show default
source: f7bba9af-297c-4e88-952d-06f960ccb4bc
volatile.initial_source: /dev/loop0
driver: btrfs
- /1.0/profiles/default
status: Created
locations:
- none
% sudo lxc storage info default
info:
driver: btrfs
space used: 52.16GiB
total space: 64.00GiB
used by:
