In ZFS Pool , is it possible add hard disk drive Space from the another Node.
Suppose we created Zpool in one Server and from the second server hard disk drive space can allocated to the created Zpool.
Thank you
Thank you
I have never tried something like that, but the only way I can think of is using NFS to mount the remote drive and then add it to the pool. If the remote drive is not ZFS or can’t be added to the pool, you could create a ZFS image on it instead.
