Hi all, I have 2 pools, “z64” the system drive for my containers and “z600” the data drive for my containers. z600 is now faulted and seems to be preventing LXD from starting. The data on z600 is not super important, but I wouldn’t mind getting it back if it’s not too involved. Here’s what I’m seeing based on things I’ve gathered from some other posts. Please let me know if any additional information will help me get to the root of the problem.
lxc list
Error: Get “http://unix.socket/1.0”: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: no such file or directory
systemctl stop lxd.service lxd.socket
Failed to stop lxd.service: Unit lxd.service not loaded.
Failed to stop lxd.socket: Unit lxd.socket not loaded.lxd --debug --group lxd
DBUG[01-21|12:04:54] Mount started driver=zfs pool=z600
DBUG[01-21|12:04:54] Mount finished driver=zfs pool=z600
EROR[01-21|12:04:54] Failed to start the daemon: Failed initializing storage pool “z600”: Failed to run: zpool import z600: cannot import ‘z600’: pool was previously in use from another system.
Last accessed by (hostid=0) at Wed Jan 20 23:42:11 2021
The pool can be imported, use ‘zpool import -f’ to import the pool.
Error: Failed initializing storage pool “z600”: Failed to run: zpool import z600: cannot import ‘z600’: pool was previously in use from another system.
The pool can be imported, use ‘zpool import -f’ to import the pool.zpool import -f z600
cannot import ‘z600’: I/O error
Recovery is possible, but will result in some data loss.
Returning the pool to its state as of Wed 20 Jan 2021 11:41:40 PM CST
should correct the problem. Approximately 31 seconds of data
must be discarded, irreversibly. Recovery can be attempted
by executing ‘zpool import -F z600’. A scrub of the pool
is strongly recommended after recovery.zpool import -F z600
The pool can be imported, use ‘zpool import -f’ to import the pool.zpool import -d z600
no pools available to import
zpool import -d /dev/sdc1
pool: z600
state: FAULTED
status: The pool metadata is corrupted.
action: The pool cannot be imported due to damaged devices or data.
The pool may be active on another system, but can be imported using
the ‘-f’ flag.
see: ZFS Message ID: ZFS-8000-72
config:z600 FAULTED corrupted data sdc ONLINE
lxc storage list
which lxd
/snap/bin/lxd
lxd --version
4.0.4
