What is the output of sudo update-grub?
I did an update to 22.04 from 20.04 today and everything is running perfectly. I am not seeing this bug.
Which “bug”. There were a couple talked about in the thread
I am seeing absolutely no problems.
Hi Brian, I got a very similar situation, and the cultprit was surprisingly umask. I wonder if this is also the case for you.
FWIW worth, after upgrading my Ubuntu 20.04 to 22.04, all the servers have the same issue when I try to create a Centos/7
lxc launch images:centos/7 centtie-7
Gives me error:
Error: The image used by this instance requires a CGroupV1 host system
I’ve tried the various suggestions of changing the umask detailed here
I had also tried changing the line in my /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash systemd.unified_cgroup_hierarchy=false"
and then doing:
sudo grub-mkconfig -o /boot/grub/grub.cfg
and then rebooting the host.
None of those helped alleviate the problem. Am I missing a step somewhere. I have no issue creating this on a Ubuntu 20.04 host. I can create Ubuntu and Debian latest versions of containers fine. I haven’t tried really old versions beside the centos 7 yet.
I’m running lxd version 5.8 on all the servers.
uname -a
on my Arm host is running
5.15.0-1026-aws 2022 aarch64 aarch64 aarch64 GNU/Linux
on one of my x64 hosts having the same issue, I’m running
5.15.0-50-generic 2022 x86_64 x86_64 x86_64 GNU/Linux
Forgot to mention, I also tried:
sudo upgrade-grub
and the output is
Sourcing file
/etc/default/grub' Sourcing file/etc/default/grub.d/40-force-partuuid.cfg’
Sourcing file/etc/default/grub.d/50-cloudimg-settings.cfg' Sourcing file/etc/default/grub.d/init-select.cfg’
Generating grub configuration file …
GRUB_FORCE_PARTUUID is set, will attempt initrdless boot
Found linux image: /boot/vmlinuz-5.15.0-1026-aws
Found initrd image: /boot/initrd.img-5.15.0-1026-aws
Found linux image: /boot/vmlinuz-5.15.0-1022-aws
Found initrd image: /boot/initrd.img-5.15.0-1022-aws
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings …
done
The other hosts I have having the issue are all physical machines. This is the only one that is a Virtual machine. They all return similar output
What does cat /proc/cmdline show?
For this
cat /proc/cmdline
One of my x64 physical hosts with the issue has
BOOT_IMAGE=/vmlinuz-5.15.0-50-generic root=/dev/mapper/lvm-root ro console=ttyS1,115200n8 quiet
another physical host I recently upgraded with same issue has
BOOT_IMAGE=/vmlinuz-5.15.0-48-generic root=/dev/mapper/lvm-root ro quiet splash console=ttyS1,115200n8 vt.handoff=7
the amazon ARM VM one with same issue has:
BOOT_IMAGE=/boot/vmlinuz-5.15.0-1026-aws root=PARTUUID=5141fba5-5f1f-4a10-b95e-5ddeff69ef83 ro console=ttyS0 nvme_core.io_timeout=4294967295 panic=-1
So I do this:
Edit /etc/default/grub and ensure that GRUB_CMDLINE_LINUX contains systemd.unified_cgroup_hierarchy=false:
E.g.
GRUB_CMDLINE_LINUX="systemd.unified_cgroup_hierarchy=false"
Then run:
sudo update-grub
Then reboot, and you should see it in the kernel cmdline:
cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.15.0-56-generic root=UUID=3710b4e6-c6e9-4675-a1b2-53f524dce111 ro systemd.unified_cgroup_hierarchy=false quiet splash console=tty1 console=ttyS0 vt.handoff=7
Thanks that did the trick. I guess my mistake before was putting it in the GRUB_CMDLINE_LINUX_DEFAULT line instead of the GRUB_CMDLINE_LINUX line
