$ incus version
Client version: 6.5
Server version: 6.5
$ incus launch docker:mysql mysql \
-c environment.MYSQL_DATABASE=wordpress \
-c environment.MYSQL_USER=wordpress \
-c environment.MYSQL_PASSWORD=wordpress \
-c environment.MYSQL_RANDOM_ROOT_PASSWORD=1
Launching mysql
$ incus exec mysql -- mysql -h localhost -u wordpress -p
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 19
Server version: 9.0.1 MySQL Community Server - GPL
Copyright (c) 2000, 2024, Oracle and/or its affiliates.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> SHOW DATABASES;
| Database |
| information_schema |
| performance_schema |
| wordpress |
3 rows in set (0.00 sec)
mysql> CONNECT wordpress;
Connection id: 20
Current database: wordpress
mysql> SHOW TABLES;
Empty set (0.00 sec)
mysql> quit
Bye
It should not require to shutdown the system. I think incus restart --force has the same exact effect. And in fact, indeed the mysql application container fails predictably to restart.
$ incus restart --force mysql
Enter password:
<<<back to shell>>>
Error: Instance is not running
Then,
$ incus start mysql
Enter password:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)
Can you test in a VM whether the docker:mysql in Docker fails, when you incus restart --force the VM? Because if it fails there are well, then it’s a container problem. Perhaps you are supposed to fix manually during an abrupt shutdown?
Since you tried docker:mysql with Docker in a VM and it works when you abruptly restart the VM (incus restart --force docker-in-a-vm) multiple times, but fails when you restart the application container (incus restart --force application-container-mysql), then something unexpected happens in the application container that requires investigation.
How do you investigate? When you start (again) the application container, add --console to see the console messages.
$ incus start mysql --console
To detach from the console, press: <ctrl>+a q
2024-10-01 13:07:43+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-10-01 13:07:43+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 9.0.1-1.el9 started.
2024-10-01 13:07:43+00:00 [Note] [Entrypoint]: Initializing database files
2024-10-01T13:07:43.566534Z 0 [System] [MY-015017] [Server] MySQL Server Initialization - start.
2024-10-01T13:07:43.568025Z 0 [System] [MY-013169] [Server] /usr/sbin/mysqld (mysqld 9.0.1) initializing of server in progress as process 97
2024-10-01T13:07:43.576523Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-10-01T13:07:43.693780Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2024-10-01T13:07:44.283930Z 6 [Warning] [MY-010453] [Server] root@localhost is created with an empty password ! Please consider switching off the --initialize-insecure option.
2024-10-01T13:07:45.453367Z 0 [System] [MY-015018] [Server] MySQL Server Initialization - end.
2024-10-01 13:07:45+00:00 [Note] [Entrypoint]: Database files initialized
2024-10-01 13:07:45+00:00 [Note] [Entrypoint]: Starting temporary server
mysqld will log errors to /var/lib/mysql/mysql.err
2024-10-01T13:07:46.034833Z 0 [ERROR] [MY-010946] [Server] Failed to start mysqld daemon. Check mysqld error log.
2024-10-01 13:07:46+00:00 [ERROR] [Entrypoint]: Unable to start server.
Error: stat /proc/-1: no such file or directory
What you need to do, is enable logging/debugging in MySQL. I did not see and interesting logs. Are they disabled until you enable them?
When you first launch the docker:mysql container, you can get a shell in there with this. Then, looks into /etc/my.cnf on enabling more debugging.
@stgraber thank you for the fix, I don’t face that issue anymore but I notice something wired when restart my server the MySQL container will start again but without database (like it remove or something similar)
that issue occurred many times from last month till now
With OCI, it’s your responsibility to create a persistent data volume and mount it on /var/lib/mysql, just as you would have to do if you were using docker.
Important note: There are several ways to store data used by applications that run in Docker containers. We encourage users of the mysql images to familiarize themselves with the options available, including:
… docker run --name some-mysql -v /my/own/datadir:/var/lib/mysql -e MYSQL_ROOT_PASSWORD=my-secret-pw -d mysql:tag
in docker, you can stop the container and it will remain storing the volume and you will need to mount directory only when you want to delete/recreate the container so the data will be stored
It was a really bad idea for docker not to reinitialize containers when they are stopped and restarted; it makes people treat them like “pets” instead of “cattle”.
I would take a step back and think about why there is an option to define a separate data volume during instance creation. It is actually best practice to separate or decouple your data from the OS. Usually your data is growing and need much more space but doesn’t need fast storage or you backup / snapshot the data more often etc.
