Cephfs storage add gives Error: Failed to mount using "ceph": no route to host
Nope, I’ve not used the new volume stuff yet. We’ll have to see how to support that in a way which doesn’t break a system running an older ceph client.
The syntax you used for your source= was already valid prior to volumes becoming a thing, it’d have basically expected a cephfs filesystem instance and then used the path /volumes/benaryorg/incus/e7c5cd0c-10fa-42e2-9d48-902544f13d07 inside it as the base for that pool. So I don’t think we can safely reuse that syntax.
@phillippe I had the same problem, and here is the solution I found:
ceph config set global ms_bind_ipv4 false
