Container creation on directory storage using BeegFS stuck
You were right: FATAL ERROR: create_inode: failed to create hardlink, because Operation not permitted.
I’ve made changes to BeegFS to create symlinks when hardlinks are requested; this got me past this issue. Sadly the next issue was
Error: Failed instance creation: Failed creating instance from image: Unpack failed: Failed to run: unsquashfs -f -d /var/snap/lxd/common/lxd/storage-pools/beegfs/containers/unified-tortoise/rootfs -n /var/snap/lxd/common/lxd/images/95f82d22bea6a0d20dc3c06a59929b768abd0c7243d5298c3973f1808688d117.rootfs: Process exited with non-zero value 2 (write_xattr: failed to write xattr security.capability for file /var/snap/lxd/common/lxd/storage-pools/beegfs/containers/unified-tortoise/rootfs/usr/bin/mtr-packet because extended attributes are not supported by the destination filesystem
Ignoring xattrs in filesystem
To avoid this error message, specify -no-xattrs)
I changed the LXD code to supply the -no-xattrs flag; after which the launch worked, however I can’t exec into the container as lxc exec just sits there doing nothing.
At this point I am afraid I need some help from the devs to know whether or not running lxd without xattrs and hardlinks is even supported.
That’s cool.
Similar problem on GlusterFS here (no workaround, but some hints, though).
@stgraber that thread had no conclusion, is there anything we could try here?
