Containers not getting ipv4
I am using Ubuntu 20.04 Lxd v 4.0.5
container is not getting IP
root@test24:/etc/netplan# lxc profile show br0profile
config: {}
description: Bridged networking LXD profile
    nictype: bridged
    parent: br0
- /1.0/instances/testserver1
- /1.0/instances/testserver2
root@test24:/etc/netplan# lxc config show testserver2
  image.architecture: amd64
  image.description: ubuntu 20.04 LTS amd64 (release) (20210325)
  image.label: release
  image.os: ubuntu
  image.release: focal
  image.serial: "20210325"
  image.type: squashfs
  image.version: "20.04"
  volatile.base_image: 46701fa2d99c72583f858c50a25f9f965f06a266b997be7a57a8e66c72b5175b
  volatile.eth0.host_name: veth7ae01572
  volatile.eth0.hwaddr: 00:16:3e:11:d5:12
  volatile.idmap.base: "0"
  volatile.uuid: d0177ed5-66cc-461f-8d2b-ca49df95009b
    ipv4.address: 172.17.5.22
    nictype: bridged
    parent: br0
- br0profile
root@test24:/etc/netplan# lxc shell testserver2
root@testserver2:~# ip addr
    inet6 ::1/128 scope host
45: eth0@if46: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:11:d5:12 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet6 fe80::216:3eff:fe11:d512/64 scope link
on the host bridge is setup like this
root@test24:/etc/netplan# more 00-installer-config.yaml
# This is the network config written by 'subiquity'
network:
  version: 2
  bonds:
    bond0:
      interfaces:
        - eno1
        - eno2
      parameters:
        mode: active-backup
        primary: eno1
  ethernets:
    eno1: {}
    eno2: {}
  bridges:
    br0:
      addresses:
       - 172.17.1.24/16
      dhcp4: false
      gateway4: 172.17.1.1
      nameservers:
        addresses:
         - 8.8.8.8
         - 172.17.1.104
         - 172.17.1.106
        search:
         - xxxxx.com
      interfaces:
       - bond0
      parameters:
       stp: true
       forward-delay: 4
      dhcp4: false
      dhcp6: false
The ipv4.address NIC setting of 172.17.5.22 will have no effect unless your instance is connected to a LXD managed bridge (because that setting is used to create a static DHCP lease in the LXD managed DHCP server). So I would suggest removing that as a starting point to avoid confusion.
In this case I believe your instance NIC is connected to an unmanaged bridge br0, which on the hosy is connected (by way of a bond) to the host’s external network.
Thus I am assuming you’re expecting an external DHCP server to be giving your instances IP config?
Have you checked your host’s firewall config (discussed in this thread) to see if its blocking DHCP packets?
Hi Thomas
Yes I am using a bridge, br0 created under netplan. Since we aren’t running a dhcp service, I was able to get it working by just updating the /etc/netplan/50-cloud-init.yaml to
network:
version: 2
ethernets:
addresses:
- 172.17.5.22/16
nameservers:
addresses:
- 8.8.8.8
- 172.17.1.104
netplan apply
Is there anyway to get the LXD containers or VMs on the LAN using the LXD managed bridge lxdbr0?
The problem will be that if you connect the lxdbr0 managed bridge to the external network then the DHCP server LXD runs on lxdbr0 will also start issuing IPs for the other devices on your external network, and start routing traffic to the LXD host as the default gateway.
You can instead run an DHCP server on the external network and then LXD’s instances will use it when connected to an unmanaged bridge.
I notice the at the br0 is getting the same mac address as one of the vm tap interfaces
72:1b:9a:60:0e:f2 i.e. the lowest one
10: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 72:1b:9a:60:0e:f2 brd ff:ff:ff:ff:ff:ff
inet 172.17.1.24/16 brd 172.17.255.255 scope global br0
inet6 fe80::8813:ff:fe08:75e5/64 scope link
58: tapcf0c3fc3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000
67: tap7431a4b9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000
link/ether da:bc:4f:4f:fb:29 brd ff:ff:ff:ff:ff:ff
Is that normal?
Yes that’s normal unless you explicitly set the Mac address of your bridge, which is a good idea to avoid it fluctuating.
The worst part is the every time I create a new VM I lose my connection to the host for 4-5 minutes. I don’t recall this happening when using KVM
That’s what happens when you bridge your physical ethernet device and don’t directly set a MAC address on the bridge. The bridge changes address every time something is added/removed to it, requiring everything on your network to do new ARP queries to talk to your host.
can I just add a made up mac address for br0 in the netplan config
or does it have to be an existing mac from one of the interfaces on the host?
bridges:
br0:
macaddress: 00:0a:2e:c9:20:03 - just add this?
addresses:
- 172.17.1.24/16
dhcp4: false
nameservers:
addresses:
- 172.17.1.104
- 172.17.1.106
search:
- ssss.com
interfaces:
- bond0
parameters:
stp: true
forward-delay: 4
dhcp4: false
dhcp6: false
That should work fine
confirmed, that worked. I no longer lose the network connection and the br0 mac doesn’t change
thank you very much
This simple solution works for me : lxc exec container_name -- dhclient
In my case my fps server had a firewall running and this interferes with the ldx firewall. The solution was to turn of the ldx firewall. I did the following:
turn of the lxd firewall
lxc network set lxdbr0 ipv4.firewall false
lxc network set lxdbr0 ipv6.firewall false
redirect the lxd firewall:
firewall-cmd --zone=trusted --change-interface=lxdbr0 --permanent
firewall-cmd --reload
Install firewall in case not available with:
apt install firewalld
Now create your container again:
lxc launch images:ubuntu/22.10 containername
and it should have ipv4
Hello! I don’t know much about networking but when I encountered this issue of no IPv4 (but IPv6 is present) on my containers after upgrading Linux Mint from 20.3 to 21.1 (for some reason) I noticed that disabling UFW solves the issue. But I need it to be enabled, so I started experimenting and found out that it looks like adding a new rule to my UFW (via Gufw) with the following settings helps:
  • Policy: Allow
  • Direction: In
  • Interface: lxdbr0
  • Protocol: UDP
  • Port: 67 (UPD: Also, it looks like adding the same rule for port 53 is required to get internet access from within containers)
Now I have 2 questions:
  1. Do you have any idea why it stopped getting IPv4 after the OS upgrade (UFW rules stayed the same, at least as I remember them)?
  2. Do you think my solution is correct for my case or is there a better one?
UPD 2: Turned out my solution doesn’t fully solve the no internet access from within containers issue :frowning:
We have a section that may help in the docs:
https://linuxcontainers.org/lxd/docs/master/howto/network_bridge_firewalld/
I am just learning LXD and ubuntu container system. I have the same IP4 issue and also see the
-A INPUT -j REJECT --reject-with icmp-host-prohibited
entry in my iptables.
My question is how did you remove it from the iptables?
Thank you
Sane rule with -D instead of -A will remove it, though you probably want to figure out what put it there to begin with.
Hey, I’ll add my experience to this thread because it may be helpful to others.
My containers were not showing their assigned ipv4 in lxc list even though they had an ipv4 assigned and networking through it worked.
I’ve finally found the cause to be the Ubuntu Mainline Kernel I’ve been running for a bit. Switching back to the Ubuntu HWE kernel solved my issue.
There was an issue with a recent mainline Linux kernel version that should be fixed by now.
Still, for production, it’s recommended to follow any supported versions provided by the distribution.
Agreed I had a similar issue and found this thread… I am using Centos Stream…
I proved the case by stopping the firewall…
sudo systemctl stop firewalld
At which point my instances all for IP addressed…
Long term I now use the following commands to resolve the problem without disabling the firewall…
sudo firewall-cmd --add-interface=lxdbr0 --zone=trusted --permanent`
sudo firewall-cmd --reload`
Hope this helps the next person that has the same problem and needs a fix :wink:
