If each project zone is a sub-domain then it should still appear as each one is in the same domain, albeit in under a sub-domain for the project.
Thank you. I tried creating zone for user project but get this error:
Error: Project isn't allowed to use this DNS zone
I tried with both:
only
features.networks.zones: "true"
and features.networks
unset
and
features.networks: "false"
lxd git-2c77027 24047 latest/edge
This is user project and profile config:
project
features.images: "true"
features.profiles: "true"
features.storage.buckets: "true"
features.storage.volumes: "true"
restricted: "true"
restricted.containers.nesting: allow
restricted.devices.disk: allow
restricted.devices.disk.paths: /home/user.name
restricted.devices.gpu: allow
restricted.idmap.gid: "5001"
restricted.idmap.uid: "1180
profile
raw.idmap: |-
uid 1180 1180
gid 5001 5001
network: lxdbr0
pool: default
Because the project is restricted you need to set restricted.networks.zones
see
This is a prefix of the zone name.
Did that work?
Hi @tomp
I have pulled LXD from edge channel and tested this, I can confirm it works as described above.
Also I understand the limitations and concerns that you described about clashing names etc.
I have noticed that each project creates their own zone. I am reviewing our DNS configuration to see whether one config can cover all the LXD zones (example lxd2.private, p1.lxd2.private, p2.lxd2.private etc.) but I think I have to create DNS config for each of these zones. So it will not be streamlined. But I will consult someone who knows bind9 well.
Thanks again for the enhancements!
