Error: Failed to retrieve PID of executing child process
Thanks for the help!
Here is the output of findmnt
Do I still need to do something :grinning_face_with_smiling_eyes:?
(I don’t open these forums very often)
We’ll be releasing a new set of stable release next week which will include the fixes from @brauner.
Thank you for the new release. It is very helpful to see unseen errors.
Here are the updates:
When i tried to find in lxc.log, i found this.
Also, i tried to use lxc monitor --pretty, and found new unseen error.
EROR[07-19|11:42:31] Error calling 'lxd forknet instanceType=container pid=186596 project=default err=β€œFailed to run: /snap/lxd/current/bin/lxd forknet info – 186596 -1: Failed setns to container network namespace: No such file or directory” instance=edc-db
Then, this is the last state
Is the error refer to cgroup or something? *cmiiw
Can you please show lxc info?
Yes, here is the output of lxc info
please let me know if you need something that i miss, so I can provide it
Sorry, I meant lxc info output withou any arguments. So just the ouput of pure lxc info.
Sorry, i misunderstood.
Here is the output.
core.https_address: 192.168.1.201:8443
core.trust_password: true
api_extensions:
– storage_zfs_remove_snapshots
– container_host_shutdown_timeout
– container_stop_priority
– container_syscall_filtering
– auth_pki
– container_last_used_at
– etag
– patch
– usb_devices
– https_allowed_credentials
– image_compression_algorithm
– directory_manipulation
– container_cpu_time
– storage_zfs_use_refquota
– storage_lvm_mount_options
– network
– profile_usedby
– container_push
– container_exec_recording
– certificate_update
– container_exec_signal_handling
– gpu_devices
– container_image_properties
– migration_progress
– id_map
– network_firewall_filtering
– network_routes
– storage
– file_delete
– file_append
– network_dhcp_expiry
– storage_lvm_vg_rename
– storage_lvm_thinpool_rename
– network_vlan
– image_create_aliases
– container_stateless_copy
– container_only_migration
– storage_zfs_clone_copy
– unix_device_rename
– storage_lvm_use_thinpool
– storage_rsync_bwlimit
– network_vxlan_interface
– storage_btrfs_mount_options
– entity_description
– image_force_refresh
– storage_lvm_lv_resizing
– id_map_base
– file_symlinks
– container_push_target
– network_vlan_physical
– storage_images_delete
– container_edit_metadata
– container_snapshot_stateful_migration
– storage_driver_ceph
– storage_ceph_user_name
– resource_limits
– storage_volatile_initial_source
– storage_ceph_force_osd_reuse
– storage_block_filesystem_btrfs
– resources
– kernel_limits
– storage_api_volume_rename
– macaroon_authentication
– network_sriov
– console
– restrict_devlxd
– migration_pre_copy
– infiniband
– maas_network
– devlxd_events
– proxy
– network_dhcp_gateway
– file_get_symlink
– network_leases
– unix_device_hotplug
– storage_api_local_volume_handling
– operation_description
– clustering
– event_lifecycle
– storage_api_remote_volume_handling
– nvidia_runtime
– container_mount_propagation
– container_backup
– devlxd_images
– container_local_cross_pool_handling
– proxy_unix
– proxy_udp
– clustering_join
– proxy_tcp_udp_multi_port_handling
– network_state
– proxy_unix_dac_properties
– container_protection_delete
– unix_priv_drop
– pprof_http
– proxy_haproxy_protocol
– network_hwaddr
– proxy_nat
– network_nat_order
– container_full
– candid_authentication
– backup_compression
– candid_config
– nvidia_runtime_config
– storage_api_volume_snapshots
– storage_unmapped
– projects
– candid_config_key
– network_vxlan_ttl
– container_incremental_copy
– usb_optional_vendorid
– snapshot_scheduling
– snapshot_schedule_aliases
– container_copy_project
– clustering_server_address
– clustering_image_replication
– container_protection_shift
– snapshot_expiry
– container_backup_override_pool
– snapshot_expiry_creation
– network_leases_location
– resources_cpu_socket
– resources_gpu
– resources_numa
– kernel_features
– id_map_current
– event_location
– storage_api_remote_volume_snapshots
– network_nat_address
– container_nic_routes
– rbac
– cluster_internal_copy
– seccomp_notify
– lxc_features
– container_nic_ipvlan
– network_vlan_sriov
– storage_cephfs
– container_nic_ipfilter
– resources_v2
– container_exec_user_group_cwd
– container_syscall_intercept
– container_disk_shift
– storage_shifted
– resources_infiniband
– daemon_storage
– instances
– image_types
– resources_disk_sata
– clustering_roles
– images_expiry
– resources_network_firmware
– backup_compression_algorithm
– ceph_data_pool_name
– container_syscall_intercept_mount
– compression_squashfs
– container_raw_mount
– container_nic_routed
– container_syscall_intercept_mount_fuse
– container_disk_ceph
– virtual-machines
– image_profiles
– clustering_architecture
– resources_disk_id
– storage_lvm_stripes
– vm_boot_priority
– unix_hotplug_devices
– api_filtering
– instance_nic_network
– clustering_sizing
– firewall_driver
– projects_limits
– container_syscall_intercept_hugetlbfs
– limits_hugepages
– container_nic_routed_gateway
– projects_restrictions
– custom_volume_snapshot_expiry
– volume_snapshot_scheduling
– trust_ca_certificates
– snapshot_disk_usage
– clustering_edit_roles
– container_nic_routed_host_address
– container_nic_ipvlan_gateway
– resources_usb_pci
– resources_cpu_threads_numa
– resources_cpu_core_die
– api_os
– container_nic_routed_host_table
– container_nic_ipvlan_host_table
– container_nic_ipvlan_mode
– resources_system
– images_push_relay
– network_dns_search
– container_nic_routed_limits
– instance_nic_bridged_vlan
– network_state_bond_bridge
– usedby_consistency
– custom_block_volumes
– clustering_failure_domains
– resources_gpu_mdev
– console_vga_type
– projects_limits_disk
– network_type_macvlan
– network_type_sriov
– container_syscall_intercept_bpf_devices
– network_type_ovn
– projects_networks
– projects_networks_restricted_uplinks
– custom_volume_backup
– backup_override_name
– storage_rsync_compression
– network_type_physical
– network_ovn_external_subnets
– network_ovn_nat
– network_ovn_external_routes_remove
– tpm_device_type
– storage_zfs_clone_copy_rebase
– gpu_mdev
– resources_pci_iommu
– resources_network_usb
– resources_disk_address
– network_physical_ovn_ingress_mode
– network_ovn_dhcp
– network_physical_routes_anycast
– projects_limits_instances
– network_state_vlan
– instance_nic_bridged_port_isolation
– instance_bulk_state_change
– network_gvrp
– instance_pool_move
– gpu_sriov
– pci_device_type
– storage_volume_state
– network_acl
– migration_stateful
– disk_state_quota
– storage_ceph_features
– projects_compression
– projects_images_remote_cache_expiry
– certificate_project
– network_ovn_acl
– projects_images_auto_update
– projects_restricted_cluster_target
– images_default_architecture
– network_ovn_acl_defaults
– gpu_mig
– project_usage
– network_bridge_acl
– warnings
– projects_restricted_backups_and_snapshots
– clustering_join_token
– clustering_description
– server_trusted_proxy
– clustering_update_cert
– storage_api_project
– server_instance_driver_operational
– server_supported_storage_drivers
api_status: stable
api_version: β€œ1.0”
auth: trusted
public: false
auth_methods:
– tls
environment:
addresses:
– 192.168.1.201:8443
architectures:
– x86_64
– i686
certificate:
certificate_fingerprint:
driver: lxc | qemu
driver_version: 4.0.9 | 5.2.0
firewall: xtables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
   netnsid_getifaddrs: β€œfalse”
   seccomp_listener: β€œfalse”
   seccomp_listener_continue: β€œfalse”
   shiftfs: β€œfalse”
   uevent_injection: β€œtrue”
   unpriv_fscaps: β€œtrue”
kernel_version: 4.18.0-80.1.2.el8_0.x86_64
lxc_features:
   cgroup2: β€œtrue”
   devpts_fd: β€œtrue”
   idmapped_mounts_v2: β€œfalse”
   mount_injection_file: β€œtrue”
   network_gateway_device_route: β€œtrue”
   network_ipvlan: β€œtrue”
   network_l2proxy: β€œtrue”
   network_phys_macvlan_mtu: β€œtrue”
   network_veth_router: β€œtrue”
   pidfd: β€œtrue”
   seccomp_allow_deny_syntax: β€œtrue”
   seccomp_notify: β€œtrue”
   seccomp_proxy_send_notify_fd: β€œtrue”
os_name: Red Hat Enterprise Linux Server
os_version: β€œ7.8”
project: default
server: lxd
server_clustered: false
server_name: mesin-aplikasi
server_pid: 200589
server_version: β€œ4.16”
storage: zfs
storage_version: 0.8.1-1
storage_supported_drivers:
– name: btrfs
   version: 5.4.1
   remote: false
– name: cephfs
   version: ceph version 15.2.12 (ce065eabfa5ce81323b009786bdf5bb03127cbe1) octopus (stable)
   remote: true
– name: dir
   version: β€œ1”
   remote: false
– name: lvm
   version: 2.03.07(2) (2019-11-30) / 1.02.167 (2019-11-30) / 4.39.0
   remote: false
– name: zfs
   version: 0.8.1-1
   remote: false
– name: ceph
   remote: true
You’re still on 4.0.9 and not on the newly tagged 4.0.10. It’s likely that it’ll be a few days until @stgraber has released a new LXD version and it has made it to the stable channels.
Alright. Thank you kindly
Hi
I want to update that I’m on 4.0.10 tagged.
Is it already on stable channels?
Thanks in advance.
Yep, LXD 4.0.7 is in the stable channel and comes with LXC 4.0.10 as shown here.
