image.architecture: amd64
image.description: Alpine 3.9 amd64 (20190321_13:00)
image.os: Alpine
image.release: "3.9"
image.serial: "20190321_13:00"
volatile.base_image: 0cbd911b5a203c7e475241b8b22cc5332d10fd30ae27916bae1558bcb118c9ce
volatile.eth0.host_name: veth196022e7
volatile.eth0.hwaddr: 00:16:3e:6b:04:12
volatile.idmap.base: "0"
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
ipv4.address: 172.16.172.116
nictype: bridged
parent: lxdbr0
pool: tank
Yep, so your eth0 NIC has a static IP defined already. So when you added a proxy in NAT mode with a connect option of tcp:0.0.0.0:7777 will use the static IP to setup the NAT rule.
In order to define a static IPv6 address, you also need to enable stateful DHCPv6 on the LXD managed network (otherwise the container may use SLAAC to generate a random IP). You will get an error to that effect when you try and define a static IPv6 address on a bridged NIC.
I did not enable stateful dhcpv6, but right now I was able to set static ipv6 address and create ipv6 proxy for that container.
Maybe you have it enabled already or you’re running an earlier version without the check.
Where can I look up that option?
lxd 4.3 15913 latest/stable canonical✓ -
lxc network show lxdbr0
ipv4.address: 10.109.89.1/24
ipv4.nat: "true"
ipv6.address: fd42:d37c:f0f2:a5f::1/64
ipv6.dhcp.stateful: "true"
ipv4.address: 172.16.172.1/24
ipv4.nat: "true"
ipv6.address: fd42:dad8:c4ad:e744::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/alp
- /1.0/instances/cms
- /1.0/instances/dd
- /1.0/instances/grr
- /1.0/instances/main
- /1.0/instances/static
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
Here’s an example of what I mean:
ipv4.nat: "true"
ipv6.nat: "true"
type: bridge
lxc init images:ubuntu/focal c1
lxc config device override c1 eth0 ipv6.address=fd42:d37c:f0f2:a5f:216:3eff:feb8:899b
Error: Invalid devices: Device validation failed "eth0": Cannot specify "ipv6.address" when "ipv6.dhcp" or "ipv6.dhcp.stateful" are disabled on network "lxdbr0"
lxc network set lxdbr0 ipv6.dhcp.stateful=true
Device eth0 overridden for c1
lxc network set lxdbr0 ipv6.dhcp.stateful=false
lxc config device set grr eth0 ipv6.address fd42:dad8:c4ad:e744:216:3eff:fecf:5770
No complaints so far. What’s the difference between set and override?.. override does not work for me:
lxc config device override grr eth0 ipv6.address=fd42:dad8:c4ad:e744:216:3eff:fecf:5770
Error: The device already exists
Set modifies an existing device in the container, but wont work if nic is from profile , override copies device config from profile into container and then modifies one or more keys on the copy.
Id need to see network and container config before and after setting ipv6 address which dhcpv6 stateful false to advise.
ns pts/0#lxc network show lxdbr0
ipv4.nat: "true"
ipv6.dhcp.stateful: "false"
ipv6.nat: "true"
volatile.bridge.hwaddr: 00:16:3e:22:17:f9
type: bridge
- /1.0/instances/dd
managed: true
status: Created
locations:
- none
Before:
ns pts/0#lxc config show grr --expanded [/home/rm 4:50 Sat 8]
image.description: Alpine 3.11 amd64 (20200705_13:00)
image.os: Alpine
image.release: "3.11"
image.serial: "20200705_13:00"
image.type: squashfs
volatile.base_image: 6d6ea490506430013373d4049212fc2412a7b62e63a8807ddeaba8dbefa128f5
volatile.eth0.host_name: veth934917ee
volatile.eth0.hwaddr: 00:16:3e:cf:57:70
ipv4.address: 172.16.172.113
nictype: bridged
parent: lxdbr0
proxy777:
connect: tcp:0.0.0.0:777
listen: tcp:168.235.88.175:777
nat: "true"
type: proxy
proxy777v6:
connect: tcp:[::]:777
listen: tcp:[2604:180:2:5f8::2]:777
nat: "true"
type: proxy
pool: tank
Setting ipv6 address:
ns pts/0#lxc config device set grr eth0 ipv6.address fd42:dad8:c4ad:e744:216:3eff:fecf:5770
ns pts/0#
After:
ns pts/0#lxc config show grr --expanded [/home/rm 4:51 Sat 8]
image.os: Alpine
ipv6.address: fd42:dad8:c4ad:e744:216:3eff:fecf:5770
nictype: bridged
parent: lxdbr0
proxy777:
nat: "true"
type: proxy
proxy777v6:
nat: "true"
type: proxy
pool: tank
I cant tell for sure because the output is from the command run with the --expanded argument which includes the profiles config. But I suspect the container has its own eth0 device, which is what allows set to run.
Ah, sorry, I’d forgotten what was the issue we were discussing, your other thread reminded me, it was the ability to set a static IPv6 with stateful off.
I presume you enabled stateful DHCP on the network, then set the NIC’s static IP, and then turned off stateful on the parent network (I don’t think there is a check when disabling stateful that checks all linked NICs for incompatible options).
Note: Even if you have been able to do that, as @stgraber said on the other thread, that static IP won’t take effect unless the parent network actually has stateful mode enabled.
Ah, no, sorry again, I checked the code and the check for parent network having stateful mode enabled is only implemented if using the NIC network=<parent> option not the parent=<parent> approach you’ve used here.
We haven’t enforced the IP allocation rules when using the parent=<parent> option because you can specify an unmanaged parent bridge with that option, and there are plans to allow users to enable the security.ip_filtering* features on a NIC when using an unmanaged parent which would be blocked if we replicated the stateful check in this configuration.
See Isolation of LXD containers? for a recent discussion about this.
