There have been a few attempts to create “docker type” files for LXD. The latest attempt being lxdops but this hasn’t got much traction based on the forums.
The quickest and easiest way to have a docker like experience would be to build and distribute images. But distributing images cost money. You have to build, store, & serve images for each architecture which adds up quick.
The next obvious solution is to distribute “text files” (json, yaml, custom-format) that set’s up containers & instances. This comes with its own set of problems, namely volume configuration when it comes to updates as we cant just blow away the whole machine. Any software that solved this problem would in essence be competing with SNAP and so is unlikely to gain any traction as canonical are unlikely push it.
The LXD crowd is normally quite technically minded and cloud-init is whats usually employed to solve the problems you are having with quick setups. But cloud-init is normally always custom and people dont need a “base image” (beyond an OS) that builds nginx / apache for them because its as simple as adding 1 line to a cloud-init.yaml.
It might be worth expressing problems you are having (“Is there a template for XYZ program”) vs general complaints as people cant build software around “it doesn’t fit a use case / onboarding problem i’m not explaining”.
We have multiple private repositories, for clients only.
But could try to make a test public repository, if anyone in this community interested to collaborate.
Clients through webpanel initiate their own repository, can than push an own container as image, a simple streams server handles the indexing.
By a dropdown list, they choose that image to launch a container.
The image creation is another module, which selects a basic os, from prepared yaml objects, choose addons, than image will be freshly created from that mix.
Centos7+ sshserver+ nginx+php+postgresql, nextcloud, wordpress …
The yaml objects of,each module contain the necessary apt / yum/apk as well as some special config along its dependancies.
A long yaml as a merge of that mix get created, fresh os fetched, nextcloud.tar.gz or binary … fetched and image created.
Hi, late reply but could still be useful
I worked on a simillar project you could be interested (but only for lxc images) https://lxc-images.soubilabs.xyz
It is open on github so new images can be added (via issues or/and pull requests)
the images are created using distrobuilder and a bit simplified with some templating
Let me know what you think about it and if it makes sens for you
I was wondering if it would be possible to adapt the great work that TTeck did on the Proxmox scripts (GitHub - tteck/Proxmox: Proxmox VE Helper-Scripts) to create Incus LXCs instead of Proxmox ones?
