Hi!
There was no response from the Snapcraft forum ;-(.
I suggest the next step would be to compile Kodi in a LXD container according to the instructions at
https://github.com/linuxserver/docker-kodi-headless
I converted the Dockerfile to a shell script and it just finished compiling
Create a new LXC container with Ubuntu 16.04
lxc launch ubuntu:16.04 kodi-headless -
Get a shell to that container,
lxc exec kodi-headless -- sudo --user ubuntu --login -
Grab a copy of the compilation shell script at https://gist.github.com/simos/ab8e0e3ac5889a3090b9be953c81150b
cd wget https://gist.githubusercontent.com/simos/ab8e0e3ac5889a3090b9be953c81150b/raw/97d2a843878734c48a02caa404f3ee0d1602d82a/kodi-headless-ubuntu1604.sh -
Run the script. It will take some time to compile Kodi with the --headless option.
bash kodi-headless-ubuntu1604.sh -
When the script finishes, you will have a
kodiexecutable in your path. I do not know match about Kodi, though you can run withkodi --headlessand it appears to work (i.e. does not complain about the option).
The two issues that are remaining are:
- You need to do the port forwarding according to the instructions shown earlier.
- You might need to attach a device with media to the
kodi-headlesscontainer.
Good luck!
