Simply splendid, Thomas!
For some reason the sqlite3 command did not work:
$ sudo sqlite3 -table /var/snap/lxd/common/lxd/database/global/db.bin 'select storage_volumes_config.id as configID, storage_volumes.name, key, value from storage_volumes left join storage_volumes_config on storage_volumes.id = storage_volumes_config.storage_volume_id where storage_volumes.type = 0 and storage_volumes_config.key = "size";'
sqlite3: Error: unknown option: -table
Use -help for a list of options.
but after some man page reading and googling, I managed this
$ sudo sqlite3
SQLite version 3.31.1 2020-01-27 19:55:54
Enter ".help" for usage hints.
Connected to a transient in-memory database.
Use ".open FILENAME" to reopen on a persistent database.
sqlite> .open /var/snap/lxd/common/lxd/database/global/db.bin
sqlite> select storage_volumes_config.id as configID, storage_volumes.name, key, value from storage_volumes left join storage_volumes_config on storage_volumes.id = storage_volumes_config.storage_volume_id where storage_volumes.type = 0 and storage_volumes_config.key = "size";
14|mythserver|size|64GB
28|local-nextcloud-server|size|21GB
32|nextcloud|size|21GB
53|roundcube|size|21GB
161|mailinabox|size|21GB
205|mailserver|size|21GB
260|ldap|size|21GB
287|myNCcontainer|size|21GB
374|nextcloud/snap0|size|21GB
376|d2ks|size|21GB
383|iredmail|size|21GB
sqlite>
Dang, thatās near all of them! I then created the patch.global.sql with the delete statement and reloaded lxd. Voila! LXD is running and lxc list now returns all my container state (plus Iām able to start the containers that I rely on).
Thank you so much! I could never have figured this out on my own!
I do have some latent errors on startup:
time="2022-08-07T15:37:40-07:00" level=error msg="Failed to update image" err="context canceled" fingerprint=712a5836865525eecd8b429afa7430e8a2480aeff68804c59a0524dc8b7683ab project=default
tail: lxd.log: file truncated
time="2022-08-07T15:37:42-07:00" level=warning msg=" - Couldn't find the CGroup blkio.weight, disk priority will be ignored"
time="2022-08-07T15:37:42-07:00" level=warning msg=" - Couldn't find the CGroup memory swap accounting, swap limits will be ignored"
time="2022-08-07T15:37:45-07:00" level=warning msg="Failed to initialize fanotify, falling back on fsnotify" err="Failed to initialize fanotify: invalid argument"
Not sure if these need any attention.
Thanks again,
-brmiller
