I deleted my post as you’re already using limits.memory.enforce: hard
how come the hard enforcement is being breached/ignored?
I dont see that it is.
Status: RUNNING
Type: container
PID: 898849
Created: 2022/08/30 15:22 UTC
Last Used: 2022/08/31 15:12 UTC
Resources:
Processes: 108
Disk usage:
root: 8.59GiB
CPU usage:
CPU usage (in seconds): 2265
Memory usage:
Memory (current): 1.14GiB
Memory (peak): 1.15GiB
Network usage:
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 16.33MB
Bytes sent: 16.33MB
Packets received: 36806
Packets sent: 36806
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
Type: broadcast
State: UP
Host interface: veth029787da
MAC address: 00:16:3e:ae:e1:99
MTU: 1500
Bytes received: 20.97MB
Bytes sent: 808.35kB
Packets received: 10971
Packets sent: 9296
IP addresses:
inet: 10.246.113.69/24 (global)
inet6: fd42:1c39:f4e9:c730:216:3eff:feae:e199/64 (global)
inet6: fe80::216:3eff:feae:e199/64 (link)
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20220706)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20220706"
image.type: squashfs
image.version: "20.04"
limits.cpu.allowance: 7ms/10ms
limits.cpu.priority: "10"
limits.memory: 10%
limits.memory.swap.priority: "10"
security.privileged: "true"
volatile.base_image: 092b0fffbcb845872ec4a595eb4e57832e14bbda5018789ca0b1838c3c5c23d0
volatile.cloud-init.instance-id: db30aa82-f419-46c7-a0e7-79d1ffa249dc
volatile.eth0.host_name: veth029787da
volatile.eth0.hwaddr: 00:16:3e:ae:e1:99
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 575b90a0-72a4-4f67-8118-df8927a7d587
COINPORT:
connect: tcp:127.0.0.1:45328
listen: tcp:0.0.0.0:45328
proxy_protocol: "false"
type: proxy
network: lxdbr0
host:
path: /home/host
readonly: "false"
shift: "true"
source: /io
pool: default
So a limit of 10%, will restrict to about 6.5GB per container:
And the peak usage is 1.15GiB
and they all slow to a grinding holt even though one daemon CPU: 66.7, MEM: 8.1
394 root 34 14 2853208 522948 153096 S 66.7 8.1 42:48.03 SAPP.daemon
Yep, so you think its due to swapping?
I’m guessing, I’ve been struggling trying all sorts of lxd settings for a few weeks now, I even tried LVM instead of zfs to see if it acted differently
shouldn’t the container show how much swap it’s using?
No, see my earlier post explaining why not:
Anything interesting in sudo dmesg
on the host?
dmesg output is so large it fills the whole terminal
[88657.823050] audit: type=1400 audit(1661877596.422:656): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=363105 comm="apparmor_parser"
[88657.824093] audit: type=1400 audit(1661877596.422:657): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=363110 comm="apparmor_parser"
[88657.824102] audit: type=1400 audit(1661877596.422:658): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=363110 comm="apparmor_parser"
[88657.824108] audit: type=1400 audit(1661877596.422:659): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=363110 comm="apparmor_parser"
[88657.824166] audit: type=1400 audit(1661877596.422:660): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=363109 comm="apparmor_parser"
[88657.824179] audit: type=1400 audit(1661877596.422:661): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=363109 comm="apparmor_parser"
[88658.174120] kauditd_printk_skb: 5 callbacks suppressed
[88658.174125] audit: type=1400 audit(1661877596.770:667): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap-update-ns.lxd" pid=363126 comm="apparmor_parser"
[88658.205060] audit: type=1400 audit(1661877596.802:668): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.hook.install" pid=363133 comm="apparmor_parser"
[88658.205115] audit: type=1400 audit(1661877596.802:669): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.lxc-to-lxd" pid=363136 comm="apparmor_parser"
[88658.225407] audit: type=1400 audit(1661877596.822:670): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.buginfo" pid=363129 comm="apparmor_parser"
[88658.225436] audit: type=1400 audit(1661877596.822:671): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.migrate" pid=363138 comm="apparmor_parser"
[88658.244356] audit: type=1400 audit(1661877596.842:672): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.benchmark" pid=363128 comm="apparmor_parser"
[88658.245045] audit: type=1400 audit(1661877596.842:673): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.activate" pid=363127 comm="apparmor_parser"
[88658.254369] audit: type=1400 audit(1661877596.850:674): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.hook.remove" pid=363134 comm="apparmor_parser"
[88658.264463] audit: type=1400 audit(1661877596.862:675): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.daemon" pid=363131 comm="apparmor_parser"
[88658.265223] audit: type=1400 audit(1661877596.862:676): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.hook.configure" pid=363132 comm="apparmor_parser"
[88666.064146] kauditd_printk_skb: 7 callbacks suppressed
[88666.064149] audit: type=1400 audit(1661877604.663:684): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=363306 comm="(d-logind)" srcname="/" flags="rw, rbind"
[88667.376217] audit: type=1400 audit(1661877605.975:685): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=363337 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[88667.976969] audit: type=1400 audit(1661877606.575:686): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=363347 comm="(mManager)" srcname="/" flags="rw, rbind"
[88674.863915] audit: type=1400 audit(1661877613.463:687): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/snap/" pid=363291 comm="snap-confine" flags="rw, rshared"
[88674.864444] audit: type=1400 audit(1661877613.463:688): apparmor="DENIED" operation="ptrace" namespace="root//lxd-bir_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=363030 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[88676.176810] audit: type=1400 audit(1661877614.775:689): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=363458 comm="(imedated)" srcname="/" flags="rw, rbind"
[88678.911312] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91499.647855] audit: type=1400 audit(1661880438.273:690): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_archive-var-snap-lxd-common-lxd-backups-lxd_backup_2173109858" pid=389338 comm="apparmor_parser"
[91499.749528] audit: type=1400 audit(1661880438.377:691): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_archive-var-snap-lxd-common-lxd-backups-lxd_backup_2173109858" pid=389342 comm="apparmor_parser"
[91507.508452] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91508.701895] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91508.858481] audit: type=1400 audit(1661880447.485:692): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" pid=389530 comm="apparmor_parser"
[91509.950761] audit: type=1400 audit(1661880448.577:693): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/proc/389540/fd/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91509.950778] audit: type=1400 audit(1661880448.577:694): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91510.032268] audit: type=1400 audit(1661880448.661:695): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91510.542106] audit: type=1400 audit(1661880449.169:696): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91514.084923] audit: type=1400 audit(1661880452.713:697): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.768458] audit: type=1400 audit(1661880466.397:698): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.768485] audit: type=1400 audit(1661880466.397:699): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.899178] audit: type=1400 audit(1661880466.525:700): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.899208] audit: type=1400 audit(1661880466.525:701): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.963466] audit: type=1400 audit(1661880466.589:702): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91527.963475] audit: type=1400 audit(1661880466.589:703): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91528.019446] audit: type=1400 audit(1661880466.645:704): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91528.019455] audit: type=1400 audit(1661880466.645:705): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91528.076773] audit: type=1400 audit(1661880466.705:706): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91528.076782] audit: type=1400 audit(1661880466.705:707): apparmor="DENIED" operation="open" profile="lxd_archive-var-snap-lxd-common-lxd-storage-pools-default-containers-pny" name="/var/snap/lxd/23270/" pid=389540 comm="tar" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91620.473426] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91632.225387] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91647.514741] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91660.998975] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91661.357489] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91671.932101] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[91671.995211] lxdbr0: port 6(veth67bfe5d3) entered blocking state
[91671.995213] lxdbr0: port 6(veth67bfe5d3) entered disabled state
[91671.995296] device veth67bfe5d3 entered promiscuous mode
[91672.317425] kauditd_printk_skb: 9 callbacks suppressed
[91672.317428] audit: type=1400 audit(1661880610.943:717): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-pny_</var/snap/lxd/common/lxd>" pid=391357 comm="apparmor_parser"
[91672.542588] phys4qSB9r: renamed from veth4f11e8bc
[91672.568361] eth0: renamed from phys4qSB9r
[91672.603988] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[91672.604075] lxdbr0: port 6(veth67bfe5d3) entered blocking state
[91672.604079] lxdbr0: port 6(veth67bfe5d3) entered forwarding state
[91675.936714] audit: type=1400 audit(1661880614.563:718): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/snap/" pid=391494 comm="mount" flags="rw, shared"
[91676.434871] audit: type=1400 audit(1661880615.063:719): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=391534 comm="apparmor_parser"
[91676.460809] audit: type=1400 audit(1661880615.087:720): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=391537 comm="apparmor_parser"
[91676.471322] audit: type=1400 audit(1661880615.099:721): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=391539 comm="apparmor_parser"
[91676.471330] audit: type=1400 audit(1661880615.099:722): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=391539 comm="apparmor_parser"
[91676.471336] audit: type=1400 audit(1661880615.099:723): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=391539 comm="apparmor_parser"
[91676.471342] audit: type=1400 audit(1661880615.099:724): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/{,usr/}sbin/dhclient" pid=391539 comm="apparmor_parser"
[91676.475779] audit: type=1400 audit(1661880615.103:725): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=391540 comm="apparmor_parser"
[91676.475788] audit: type=1400 audit(1661880615.103:726): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=391540 comm="apparmor_parser"
[91681.059757] kauditd_printk_skb: 20 callbacks suppressed
[91681.059759] audit: type=1400 audit(1661880619.687:747): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391638 comm="(networkd)" srcname="/" flags="rw, rbind"
[91681.297300] audit: type=1400 audit(1661880619.923:748): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391646 comm="(resolved)" srcname="/" flags="rw, rbind"
[91685.105096] audit: type=1400 audit(1661880623.731:749): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391734 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[91685.106840] audit: type=1400 audit(1661880623.735:750): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391731 comm="(d-logind)" srcname="/" flags="rw, rbind"
[91686.691667] audit: type=1400 audit(1661880625.319:751): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391783 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[91687.632015] audit: type=1400 audit(1661880626.259:752): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391805 comm="(mManager)" srcname="/" flags="rw, rbind"
[91693.867613] audit: type=1400 audit(1661880632.495:753): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/snap/" pid=391728 comm="snap-confine" flags="rw, rshared"
[91693.868037] audit: type=1400 audit(1661880632.495:754): apparmor="DENIED" operation="ptrace" namespace="root//lxd-pny_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=391446 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[91694.707526] audit: type=1400 audit(1661880633.335:755): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=391927 comm="(imedated)" srcname="/" flags="rw, rbind"
[101558.747121] new mount options do not match the existing superblock, will be ignored
[115061.924539] audit: type=1400 audit(1661904000.744:756): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=565529 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[115062.978672] audit: type=1400 audit(1661904001.800:757): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=565574 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[115069.203466] audit: type=1400 audit(1661904008.024:758): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=565679 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[115075.875300] audit: type=1400 audit(1661904014.696:759): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=565747 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[115105.800893] audit: type=1400 audit(1661904044.625:760): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=565950 comm="(ogrotate)" srcname="/" flags="rw, rbind"
[139862.755860] perf: interrupt took too long (6272 > 6271), lowering kernel.perf_event_max_sample_rate to 31750
[163463.483924] Adding 10485756k swap on /rttswapfile. Priority:-3 extents:14 across:13033468k FS
[165317.509065] physqq1hBi: renamed from eth0
[165317.536897] lxdbr0: port 1(veth005439fd) entered disabled state
[165317.543191] veth11598d1b: renamed from physqq1hBi
[165317.656276] device veth005439fd left promiscuous mode
[165317.656322] lxdbr0: port 1(veth005439fd) entered disabled state
[165318.670842] audit: type=1400 audit(1661954257.820:761): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-WWS_faucex_</var/snap/lxd/common/lxd>" pid=890008 comm="apparmor_parser"
[165318.849035] audit: type=1400 audit(1661954258.000:762): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-PORT80_faucex_</var/snap/lxd/common/lxd>" pid=890011 comm="apparmor_parser"
[165319.026796] audit: type=1400 audit(1661954258.176:763): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-PORT443_faucex_</var/snap/lxd/common/lxd>" pid=890014 comm="apparmor_parser"
[165319.930853] audit: type=1400 audit(1661954259.080:764): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-faucex_</var/snap/lxd/common/lxd>" pid=890019 comm="apparmor_parser"
[165329.121266] phys3dOSmf: renamed from eth0
[165329.144652] lxdbr0: port 2(veth6966372e) entered disabled state
[165329.151223] vetha5c03fc9: renamed from phys3dOSmf
[165329.268470] device veth6966372e left promiscuous mode
[165329.268515] lxdbr0: port 2(veth6966372e) entered disabled state
[165330.273875] audit: type=1400 audit(1661954269.425:765): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-relay_holdip_</var/snap/lxd/common/lxd>" pid=890750 comm="apparmor_parser"
[165331.105460] audit: type=1400 audit(1661954270.257:766): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-holdip_</var/snap/lxd/common/lxd>" pid=890755 comm="apparmor_parser"
[165338.780595] lxdbr0: port 4(vethc91b9238) entered disabled state
[165367.864801] physkTd9OO: renamed from eth0
[165367.912682] veth21d033e1: renamed from physkTd9OO
[165368.028014] device vethc91b9238 left promiscuous mode
[165368.028067] lxdbr0: port 4(vethc91b9238) entered disabled state
[165369.008610] audit: type=1400 audit(1661954308.161:767): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-COINPORT_asafe_</var/snap/lxd/common/lxd>" pid=891021 comm="apparmor_parser"
[165370.136000] audit: type=1400 audit(1661954309.285:768): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-asafe_</var/snap/lxd/common/lxd>" pid=891025 comm="apparmor_parser"
[165451.420276] physQpp3iY: renamed from eth0
[165451.468072] lxdbr0: port 3(veth0fa44361) entered disabled state
[165451.476271] veth0c8e6fc2: renamed from physQpp3iY
[165451.576125] device veth0fa44361 left promiscuous mode
[165451.576178] lxdbr0: port 3(veth0fa44361) entered disabled state
[165452.569434] audit: type=1400 audit(1661954391.721:769): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_forkproxy-COINPORT_sapp_</var/snap/lxd/common/lxd>" pid=891935 comm="apparmor_parser"
[165453.835409] audit: type=1400 audit(1661954392.985:770): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-sapp_</var/snap/lxd/common/lxd>" pid=891941 comm="apparmor_parser"
[165492.028239] physnCfl7H: renamed from eth0
[165492.055806] lxdbr0: port 5(vethfced07c8) entered disabled state
[165492.062886] veth73821bee: renamed from physnCfl7H
[165492.173680] device vethfced07c8 left promiscuous mode
[165492.173726] lxdbr0: port 5(vethfced07c8) entered disabled state
[165494.109927] audit: type=1400 audit(1661954433.258:771): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-bir_</var/snap/lxd/common/lxd>" pid=892644 comm="apparmor_parser"
[165550.455605] phys4qSB9r: renamed from eth0
[165550.475377] lxdbr0: port 6(veth67bfe5d3) entered disabled state
[165550.481078] veth4f11e8bc: renamed from phys4qSB9r
[165550.599942] device veth67bfe5d3 left promiscuous mode
[165550.599992] lxdbr0: port 6(veth67bfe5d3) entered disabled state
[165552.558898] audit: type=1400 audit(1661954491.706:772): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-pny_</var/snap/lxd/common/lxd>" pid=893329 comm="apparmor_parser"
[165852.796778] audit: type=1400 audit(1661954791.948:773): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>" pid=893660 comm="apparmor_parser"
[169738.783926] audit: type=1400 audit(1661958677.956:774): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=896268 comm="apparmor_parser"
[169738.783934] audit: type=1400 audit(1661958677.956:775): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/16292/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=896268 comm="apparmor_parser"
[169738.899366] audit: type=1400 audit(1661958678.072:776): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.install" pid=896276 comm="apparmor_parser"
[169738.916250] audit: type=1400 audit(1661958678.088:777): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.activate" pid=896270 comm="apparmor_parser"
[169738.962452] audit: type=1400 audit(1661958678.136:778): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.configure" pid=896275 comm="apparmor_parser"
[169738.986681] audit: type=1400 audit(1661958678.160:779): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.migrate" pid=896281 comm="apparmor_parser"
[169738.994947] audit: type=1400 audit(1661958678.168:780): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.check-kernel" pid=896273 comm="apparmor_parser"
[169738.996092] audit: type=1400 audit(1661958678.168:781): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.lxd" pid=896280 comm="apparmor_parser"
[169738.997162] audit: type=1400 audit(1661958678.168:782): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.lxc-to-lxd" pid=896279 comm="apparmor_parser"
[169738.997435] audit: type=1400 audit(1661958678.172:783): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.remove" pid=896277 comm="apparmor_parser"
[169786.456702] kauditd_printk_skb: 6 callbacks suppressed
[169786.456705] audit: type=1400 audit(1661958725.628:790): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>" pid=896998 comm="apparmor_parser"
[169787.849484] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: discard
[169787.896886] lxdbr0: port 1(veth6f1d431a) entered blocking state
[169787.896888] lxdbr0: port 1(veth6f1d431a) entered disabled state
[169787.897007] device veth6f1d431a entered promiscuous mode
[169788.115279] audit: type=1400 audit(1661958727.288:791): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-faucex_</var/snap/lxd/common/lxd>" pid=897084 comm="apparmor_parser"
[169788.261624] phys2gXA5e: renamed from veth0990fe7d
[169788.290989] eth0: renamed from phys2gXA5e
[169788.315255] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169788.315340] lxdbr0: port 1(veth6f1d431a) entered blocking state
[169788.315344] lxdbr0: port 1(veth6f1d431a) entered forwarding state
[169788.315540] IPv6: ADDRCONF(NETDEV_CHANGE): lxdbr0: link becomes ready
[169788.355429] new mount options do not match the existing superblock, will be ignored
[169788.669801] audit: type=1400 audit(1661958727.844:792): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_forkproxy-PORT443_faucex_</var/snap/lxd/common/lxd>" pid=897123 comm="apparmor_parser"
[169788.712376] audit: type=1400 audit(1661958727.884:793): apparmor="DENIED" operation="open" profile="lxd_forkproxy-PORT443_faucex_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=897125 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169788.718477] audit: type=1400 audit(1661958727.892:794): apparmor="DENIED" operation="open" profile="lxd_forkproxy-PORT443_faucex_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=897126 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169789.725789] audit: type=1400 audit(1661958728.900:795): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_forkproxy-PORT80_faucex_</var/snap/lxd/common/lxd>" pid=897174 comm="apparmor_parser"
[169789.765803] audit: type=1400 audit(1661958728.940:796): apparmor="DENIED" operation="open" profile="lxd_forkproxy-PORT80_faucex_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=897177 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169789.769192] audit: type=1400 audit(1661958728.944:797): apparmor="DENIED" operation="open" profile="lxd_forkproxy-PORT80_faucex_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=897178 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169790.224954] audit: type=1400 audit(1661958729.396:798): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/snap/" pid=897236 comm="mount" flags="rw, shared"
[169790.715492] audit: type=1400 audit(1661958729.888:799): apparmor="STATUS" operation="profile_load" label="lxd-faucex_</var/snap/lxd/common/lxd>//&:lxd-faucex_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=897296 comm="apparmor_parser"
[169793.589640] kauditd_printk_skb: 35 callbacks suppressed
[169793.589642] audit: type=1400 audit(1661958732.764:835): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897355 comm="(networkd)" srcname="/" flags="rw, rbind"
[169793.772774] audit: type=1400 audit(1661958732.944:836): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897357 comm="(resolved)" srcname="/" flags="rw, rbind"
[169796.192577] audit: type=1400 audit(1661958735.364:837): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897399 comm="(d-logind)" srcname="/" flags="rw, rbind"
[169797.054005] audit: type=1400 audit(1661958736.228:838): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897458 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[169798.082762] audit: type=1400 audit(1661958737.256:839): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897516 comm="(mManager)" srcname="/" flags="rw, rbind"
[169801.722038] audit: type=1400 audit(1661958740.896:840): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/snap/" pid=897391 comm="snap-confine" flags="rw, rshared"
[169801.722684] audit: type=1400 audit(1661958740.896:841): apparmor="DENIED" operation="ptrace" namespace="root//lxd-faucex_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=897195 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[169802.079066] audit: type=1400 audit(1661958741.252:842): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-faucex_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=897694 comm="(imedated)" srcname="/" flags="rw, rbind"
[169810.250663] EXT4-fs (dm-5): mounted filesystem with ordered data mode. Opts: discard
[169810.282599] lxdbr0: port 2(veth84c7c9ec) entered blocking state
[169810.282602] lxdbr0: port 2(veth84c7c9ec) entered disabled state
[169810.282688] device veth84c7c9ec entered promiscuous mode
[169810.526187] audit: type=1400 audit(1661958749.700:843): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-holdip_</var/snap/lxd/common/lxd>" pid=898030 comm="apparmor_parser"
[169810.673527] physqdsHGN: renamed from veth49c1689d
[169810.706924] eth0: renamed from physqdsHGN
[169810.739111] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169810.739197] lxdbr0: port 2(veth84c7c9ec) entered blocking state
[169810.739201] lxdbr0: port 2(veth84c7c9ec) entered forwarding state
[169811.414929] audit: type=1400 audit(1661958750.588:844): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_forkproxy-relay_holdip_</var/snap/lxd/common/lxd>" pid=898072 comm="apparmor_parser"
[169811.456978] audit: type=1400 audit(1661958750.628:845): apparmor="DENIED" operation="open" profile="lxd_forkproxy-relay_holdip_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=898074 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169811.457315] audit: type=1400 audit(1661958750.632:846): apparmor="DENIED" operation="open" profile="lxd_forkproxy-relay_holdip_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=898073 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169814.973294] audit: type=1400 audit(1661958754.148:847): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/snap/" pid=898176 comm="mount" flags="rw, shared"
[169815.533034] audit: type=1400 audit(1661958754.708:848): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=898225 comm="apparmor_parser"
[169815.533043] audit: type=1400 audit(1661958754.708:849): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=898225 comm="apparmor_parser"
[169815.533102] audit: type=1400 audit(1661958754.708:850): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=898224 comm="apparmor_parser"
[169815.534360] audit: type=1400 audit(1661958754.708:851): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=898223 comm="apparmor_parser"
[169815.534369] audit: type=1400 audit(1661958754.708:852): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=898223 comm="apparmor_parser"
[169815.534374] audit: type=1400 audit(1661958754.708:853): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=898223 comm="apparmor_parser"
[169815.535303] audit: type=1400 audit(1661958754.708:854): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=898222 comm="apparmor_parser"
[169815.535315] audit: type=1400 audit(1661958754.708:855): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=898222 comm="apparmor_parser"
[169815.544043] audit: type=1400 audit(1661958754.716:856): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=898227 comm="apparmor_parser"
[169815.545779] audit: type=1400 audit(1661958754.720:857): apparmor="STATUS" operation="profile_load" label="lxd-holdip_</var/snap/lxd/common/lxd>//&:lxd-holdip_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=898226 comm="apparmor_parser"
[169819.492892] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: discard
[169819.526625] lxdbr0: port 3(vetha6a0cf33) entered blocking state
[169819.526629] lxdbr0: port 3(vetha6a0cf33) entered disabled state
[169819.526746] device vetha6a0cf33 entered promiscuous mode
[169819.909412] physcJVzaq: renamed from veth99067357
[169819.934898] eth0: renamed from physcJVzaq
[169819.962979] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169819.963063] lxdbr0: port 3(vetha6a0cf33) entered blocking state
[169819.963066] lxdbr0: port 3(vetha6a0cf33) entered forwarding state
[169822.839862] kauditd_printk_skb: 29 callbacks suppressed
[169822.839866] audit: type=1400 audit(1661958762.012:887): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=898581 comm="(d-logind)" srcname="/" flags="rw, rbind"
[169823.927459] audit: type=1400 audit(1661958763.100:888): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=898635 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[169825.039878] audit: type=1400 audit(1661958764.212:889): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/lxc-start" pid=898661 comm="apparmor_parser"
[169825.114438] audit: type=1400 audit(1661958764.288:890): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=898662 comm="apparmor_parser"
[169825.114447] audit: type=1400 audit(1661958764.288:891): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=898662 comm="apparmor_parser"
[169825.114454] audit: type=1400 audit(1661958764.288:892): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=898662 comm="apparmor_parser"
[169825.228142] audit: type=1400 audit(1661958764.400:893): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=898663 comm="apparmor_parser"
[169825.228166] audit: type=1400 audit(1661958764.400:894): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=898663 comm="apparmor_parser"
[169825.277545] audit: type=1400 audit(1661958764.452:895): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default" pid=898659 comm="apparmor_parser"
[169825.277554] audit: type=1400 audit(1661958764.452:896): apparmor="STATUS" operation="profile_load" label="lxd-asafe_</var/snap/lxd/common/lxd>//&:lxd-asafe_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-cgns" pid=898659 comm="apparmor_parser"
[169828.772581] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: discard
[169828.804056] lxdbr0: port 4(veth029787da) entered blocking state
[169828.804059] lxdbr0: port 4(veth029787da) entered disabled state
[169828.804157] device veth029787da entered promiscuous mode
[169829.117377] kauditd_printk_skb: 8 callbacks suppressed
[169829.117380] audit: type=1400 audit(1661958768.292:905): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-sapp_</var/snap/lxd/common/lxd>" pid=898848 comm="apparmor_parser"
[169829.285241] physXOtzvo: renamed from vethe9668a97
[169829.318643] eth0: renamed from physXOtzvo
[169829.350940] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169829.351024] lxdbr0: port 4(veth029787da) entered blocking state
[169829.351029] lxdbr0: port 4(veth029787da) entered forwarding state
[169829.795127] audit: type=1400 audit(1661958768.968:906): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/snap/" pid=898563 comm="snap-confine" flags="rw, rshared"
[169829.795501] audit: type=1400 audit(1661958768.968:907): apparmor="DENIED" operation="ptrace" namespace="root//lxd-holdip_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=898131 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[169829.842789] audit: type=1400 audit(1661958769.016:908): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_forkproxy-COINPORT_sapp_</var/snap/lxd/common/lxd>" pid=898896 comm="apparmor_parser"
[169829.886994] audit: type=1400 audit(1661958769.060:909): apparmor="DENIED" operation="open" profile="lxd_forkproxy-COINPORT_sapp_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=898899 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169829.887450] audit: type=1400 audit(1661958769.060:910): apparmor="DENIED" operation="open" profile="lxd_forkproxy-COINPORT_sapp_</var/snap/lxd/common/lxd>" name="/sys/devices/virtual/dmi/id/product_uuid" pid=898898 comm="lxd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[169831.179943] audit: type=1400 audit(1661958770.352:911): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-holdip_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=898962 comm="(imedated)" srcname="/" flags="rw, rbind"
[169834.338088] audit: type=1400 audit(1661958773.512:912): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/snap/" pid=899087 comm="mount" flags="rw, shared"
[169835.223395] audit: type=1400 audit(1661958774.396:913): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=899125 comm="apparmor_parser"
[169835.223701] audit: type=1400 audit(1661958774.396:914): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=899129 comm="apparmor_parser"
[169835.223710] audit: type=1400 audit(1661958774.396:915): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=899129 comm="apparmor_parser"
[169835.226854] audit: type=1400 audit(1661958774.400:916): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=899130 comm="apparmor_parser"
[169835.226861] audit: type=1400 audit(1661958774.400:917): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=899130 comm="apparmor_parser"
[169835.226865] audit: type=1400 audit(1661958774.400:918): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=899130 comm="apparmor_parser"
[169835.230003] audit: type=1400 audit(1661958774.404:919): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=899127 comm="apparmor_parser"
[169835.230011] audit: type=1400 audit(1661958774.404:920): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=899127 comm="apparmor_parser"
[169835.404551] audit: type=1400 audit(1661958774.576:921): apparmor="STATUS" operation="profile_load" label="lxd-sapp_</var/snap/lxd/common/lxd>//&:lxd-sapp_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=899124 comm="apparmor_parser"
[169836.436681] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: discard
[169836.470347] lxdbr0: port 5(vethb009b141) entered blocking state
[169836.470349] lxdbr0: port 5(vethb009b141) entered disabled state
[169836.470436] device vethb009b141 entered promiscuous mode
[169837.093357] physrCfxBs: renamed from veth2a0bbbcf
[169837.127164] eth0: renamed from physrCfxBs
[169837.154940] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169837.155035] lxdbr0: port 5(vethb009b141) entered blocking state
[169837.155039] lxdbr0: port 5(vethb009b141) entered forwarding state
[169843.544214] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: discard
[169843.581180] lxdbr0: port 6(veth1b77fe60) entered blocking state
[169843.581182] lxdbr0: port 6(veth1b77fe60) entered disabled state
[169843.581273] device veth1b77fe60 entered promiscuous mode
[169843.897890] kauditd_printk_skb: 23 callbacks suppressed
[169843.897891] audit: type=1400 audit(1661958783.072:945): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-bir_</var/snap/lxd/common/lxd>" pid=899653 comm="apparmor_parser"
[169844.233229] physBZU55s: renamed from veth1c443f2c
[169844.262485] eth0: renamed from physBZU55s
[169844.294821] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[169844.294904] lxdbr0: port 6(veth1b77fe60) entered blocking state
[169844.294907] lxdbr0: port 6(veth1b77fe60) entered forwarding state
[169844.314065] audit: type=1400 audit(1661958783.488:946): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-asafe_</var/snap/lxd/common/lxd>" name="/proc/acpi/" pid=899684 comm="(ostnamed)" srcname="/proc/acpi/" flags="rw, rbind"
[169849.465462] audit: type=1400 audit(1661958788.640:947): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/snap/" pid=899802 comm="mount" flags="rw, shared"
[169850.733986] audit: type=1400 audit(1661958789.908:948): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-asafe_</var/snap/lxd/common/lxd>" name="/proc/acpi/" pid=899854 comm="(imedated)" srcname="/proc/acpi/" flags="rw, rbind"
[169851.221663] audit: type=1400 audit(1661958790.396:949): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=899861 comm="apparmor_parser"
[169851.221672] audit: type=1400 audit(1661958790.396:950): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=899861 comm="apparmor_parser"
[169851.241219] audit: type=1400 audit(1661958790.416:951): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=899859 comm="apparmor_parser"
[169851.241228] audit: type=1400 audit(1661958790.416:952): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=899859 comm="apparmor_parser"
[169851.249992] audit: type=1400 audit(1661958790.424:953): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=899860 comm="apparmor_parser"
[169851.250001] audit: type=1400 audit(1661958790.424:954): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=899860 comm="apparmor_parser"
[169851.250007] audit: type=1400 audit(1661958790.424:955): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=899860 comm="apparmor_parser"
[169851.291464] audit: type=1400 audit(1661958790.464:956): apparmor="STATUS" operation="profile_load" label="lxd-pny_</var/snap/lxd/common/lxd>//&:lxd-pny_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=899856 comm="apparmor_parser"
[169858.257223] kauditd_printk_skb: 20 callbacks suppressed
[169858.257227] audit: type=1400 audit(1661958797.432:977): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/snap/" pid=899999 comm="mount" flags="rw, shared"
[169858.833248] audit: type=1400 audit(1661958798.008:978): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900030 comm="(networkd)" srcname="/" flags="rw, rbind"
[169859.741657] audit: type=1400 audit(1661958798.916:979): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900044 comm="(resolved)" srcname="/" flags="rw, rbind"
[169859.942198] audit: type=1400 audit(1661958799.116:980): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=900041 comm="apparmor_parser"
[169859.942205] audit: type=1400 audit(1661958799.116:981): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=900041 comm="apparmor_parser"
[169859.950768] audit: type=1400 audit(1661958799.124:982): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=900037 comm="apparmor_parser"
[169859.976344] audit: type=1400 audit(1661958799.148:983): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=900040 comm="apparmor_parser"
[169859.976359] audit: type=1400 audit(1661958799.148:984): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=900040 comm="apparmor_parser"
[169859.990261] audit: type=1400 audit(1661958799.164:985): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=900042 comm="apparmor_parser"
[169859.990269] audit: type=1400 audit(1661958799.164:986): apparmor="STATUS" operation="profile_load" label="lxd-bir_</var/snap/lxd/common/lxd>//&:lxd-bir_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=900042 comm="apparmor_parser"
[169864.160710] kauditd_printk_skb: 21 callbacks suppressed
[169864.160712] audit: type=1400 audit(1661958803.332:1008): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900101 comm="(d-logind)" srcname="/" flags="rw, rbind"
[169866.400239] audit: type=1400 audit(1661958805.572:1009): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900125 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[169867.862730] audit: type=1400 audit(1661958807.036:1010): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900140 comm="(mManager)" srcname="/" flags="rw, rbind"
[169871.511850] audit: type=1400 audit(1661958810.684:1011): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900183 comm="(networkd)" srcname="/" flags="rw, rbind"
[169871.902705] audit: type=1400 audit(1661958811.076:1012): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900185 comm="(resolved)" srcname="/" flags="rw, rbind"
[169874.172842] audit: type=1400 audit(1661958813.348:1013): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900202 comm="(networkd)" srcname="/" flags="rw, rbind"
[169874.530954] audit: type=1400 audit(1661958813.704:1014): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900208 comm="(resolved)" srcname="/" flags="rw, rbind"
[169876.132176] audit: type=1400 audit(1661958815.304:1015): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900269 comm="(d-logind)" srcname="/" flags="rw, rbind"
[169877.052634] audit: type=1400 audit(1661958816.224:1016): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/snap/" pid=900098 comm="snap-confine" flags="rw, rshared"
[169877.053296] audit: type=1400 audit(1661958816.228:1017): apparmor="DENIED" operation="ptrace" namespace="root//lxd-sapp_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=899051 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[169877.972145] audit: type=1400 audit(1661958817.144:1018): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900320 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[169878.403293] audit: type=1400 audit(1661958817.576:1019): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-sapp_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900348 comm="(imedated)" srcname="/" flags="rw, rbind"
[169879.063066] audit: type=1400 audit(1661958818.236:1020): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900360 comm="(mManager)" srcname="/" flags="rw, rbind"
[169880.651748] audit: type=1400 audit(1661958819.824:1021): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900412 comm="(d-logind)" srcname="/" flags="rw, rbind"
[169882.760127] audit: type=1400 audit(1661958821.932:1022): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900461 comm="(ostnamed)" srcname="/" flags="rw, rbind"
[169883.830687] audit: type=1400 audit(1661958823.004:1023): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900476 comm="(mManager)" srcname="/" flags="rw, rbind"
[169886.871051] audit: type=1400 audit(1661958826.044:1024): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/snap/" pid=900261 comm="snap-confine" flags="rw, rshared"
[169886.871867] audit: type=1400 audit(1661958826.044:1025): apparmor="DENIED" operation="ptrace" namespace="root//lxd-pny_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=899763 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[169888.120963] audit: type=1400 audit(1661958827.296:1026): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-pny_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900582 comm="(imedated)" srcname="/" flags="rw, rbind"
[169891.166661] audit: type=1400 audit(1661958830.340:1027): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/snap/" pid=900409 comm="snap-confine" flags="rw, rshared"
[169891.170116] audit: type=1400 audit(1661958830.344:1028): apparmor="DENIED" operation="ptrace" namespace="root//lxd-bir_<var-snap-lxd-common-lxd>" profile="/snap/snapd/16292/usr/lib/snapd/snap-confine" pid=899956 comm="systemd-journal" requested_mask="readby" denied_mask="readby" peer="unconfined"
[169892.562320] audit: type=1400 audit(1661958831.736:1029): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-bir_</var/snap/lxd/common/lxd>" name="/run/systemd/unit-root/" pid=900679 comm="(imedated)" srcname="/" flags="rw, rbind"
root@h:~#
happens a lot, what is that? googling…
internal error, please report: running “lxd.lxc” failed: cannot create transient scope: DBus error “org.freedesktop.DBus.Error.TimedOut”: [Failed to activate service ‘org.freedesktop.systemd1’: timed out (service_start_timeout=25000ms)]
I followed steps to enable SWAP accounting for my system
Log into Ubuntu as a user with sudo privileges.
Edit the /etc/default/grub file.
Add or edit the GRUB_CMDLINE_LINUX line to add the following two key-value pairs:
GRUB_CMDLINE_LINUX="cgroup_enable=memory swapaccount=1"
Save and close the file.
Update GRUB.
$ sudo update-grub
If your GRUB configuration file has incorrect syntax, an error will occur. In this case, repeat steps 3 and 4.
Reboot your system. Memory and swap accounting are enabled and the warning does not occur.
now I see swap space in the containers but the swap is still not being used
top - 17:08:54 up 14 min, 0 users, load average: 2.58, 2.82, 2.10
Tasks: 19 total, 1 running, 18 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 6421476 total, 3411304 free, 2226076 used, 784096 buff/cache
KiB Swap: 6421476 total, 6421476 free, 0 used. 4195400 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND SWAP
546 root 34 14 4360052 2.134g 119776 S 0.3 34.9 5:38.57 ASAFE.daemon 0
1 root 20 0 225004 8716 6584 S 0.0 0.1 0:00.50 systemd 0
57 root 19 -1 78304 9376 8816 S 0.0 0.1 0:00.18 systemd-journal 0
188 systemd+ 20 0 79920 5752 5132 S 0.0 0.1 0:00.05 systemd-network 0
295 systemd+ 20 0 70492 4772 4304 S 0.0 0.1 0:00.02 systemd-resolve 0
299 root 20 0 25992 1276 0 S 0.0 0.0 0:00.00 dhclient 0
382 root 20 0 286252 6732 5876 S 0.0 0.1 0:00.06 accounts-daemon 0
383 syslog 20 0 267276 4180 3644 S 0.0 0.1 0:00.04 rsyslogd 0
385 root 20 0 169524 17340 9196 S 0.0 0.3 0:00.20 networkd-dispat 0
386 root 20 0 61972 5456 4884 S 0.0 0.1 0:00.03 systemd-logind 0
387 daemon 20 0 28332 2356 2152 S 0.0 0.0 0:00.00 atd 0
389 root 20 0 30028 3252 2964 S 0.0 0.1 0:00.00 cron 0
402 message+ 20 0 50104 4148 3684 S 0.0 0.1 0:00.06 dbus-daemon 0
427 root 20 0 72300 5808 5080 S 0.0 0.1 0:00.01 sshd 0
433 root 20 0 185940 20264 12368 S 0.0 0.3 0:00.15 unattended-upgr 0
437 root 20 0 288880 6576 5788 S 0.0 0.1 0:00.01 polkitd 0
438 root 20 0 14668 2248 2112 S 0.0 0.0 0:00.00 agetty 0
570 root 20 0 25468 7256 3196 S 0.0 0.1 0:00.09 bash 0
764 root 20 0 42132 3556 3076 R 0.0 0.1 0:00.85 top 0
