The syntax you’re using is to direct attach arbitrary block devices.
You shouldn’t use that with LXD custom storage volumes as those are formatted volumes managed by LXD which you should instead attach with something like:
lxc config device add INSTANCE SOME-NAME disk source=NAME pool=ceph-vault
If you need those to be raw block devices rather than filesystem mounts, then you should either wait for LXD 4.3 which will have support for block type custom volumes or you need to manually create an rbd volume outside of LXD and then attach it with the syntax you’re currently using.
ubuntu@aa1-cptef101-n1:~$ lxc --project <company>-staging2 config device add pod-890-1001-02 test disk source=testimage pool=ceph-vault
Device test added to pod-890-1001-02
and starting it:
ubuntu@aa1-cptef101-n1:~$ lxc start --project <company>-staging2 pod-890-1001-02
Error: Failed to start device "test": Failed mounting storage volume "testimage" of type "custom" on storage pool "ceph-vault": No such object
Try `lxc info --show-log pod-890-1001-02` for more info
