This is not working. The snapshot stays
any other ideas?
I think that the âsnapshotâ exists only in the LXD SQL database. I could try to give you queries to zap the rows from the database but itâs a bit out of my current experience and there should be a better way, I canât believe that LXD developers have not thought out a way to automatically fix the database when things are wrong but I have not yet found it.
Did you just try to reboot the computer, by the way, maybe thatâs the method ?
P.s
wat kernel module should i install?
Hi
first of all thank you for you responses! i allredeay rebooted multiple times. If you could tell me how to do this that would be great!
before you told me that a kernel module was missing. what module should i install (had nothing to do with the backups)
I said that a kernel feature is missing, because LXD donât find something in sysfs. But itâs not necessarily a module, it can be linked to the whole kernel, it could be found only on a more recent kernel version. I have no idea really because I have no great interest in the feature.
a ok perfect notting to worry about then.
Could you tell me how to zap the rows from the database
I think that itâs a dangerous idea . If it goes wrongâŠ
Maybe it could be possible to create manually a snapshot in the storage and then use the LXD delete snapshot command that could then (hopefully) work correctly. If this does not work, LXD devs counsel to create a new post to ask them how to fix the database with SQL.
How to create a manual snapshot; donât forget to remove the space(s) at the end(s) of the following line(s) remember the preceding problem!
1 - create a subdirectory
sudo nsenter -t $(pgrep daemon.start) -m -- mkdir /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/kopano
2 - create a snapshot in this subdirectory
sudo nsenter -t $(pgrep daemon.start) -m -- /snap/lxd/current/bin/btrfs sub snapshot /var/snap/lxd/common/lxd/storage-pools/default/containers/kopano /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/kopano/kopano -c
thank you.
this worked. now its ok again!
thank you again for you help
good, but remember that the first workaround (the mkdir sudo mkdir -p /var/snap/lxd/common/lxd/storage-pools/exports/custom/exports_volume) is NOT an innocuous fix, if you have to delete the storage pool you should not forget to remove these 2 directories before else the storage pool removal will fail.
Eww. After debian upgrade to buster previous workaround:
mount --bind /exptmp/backups /var/snap/lxd/common/lxd/backups
does not work anymore, failing with message:
Error: Create backup: Backup create: Failed to create mount directory "/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/main/backup": mkdir /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/main/backup: no such file or directory
I created exptmp volume:
# lxc storage volume create default exptmp
# lxc config set storage.backups_volume=default/exptmp
but it does not work either with the same message, lxc export still fails:
lxc export main /tank/exportfs/monthly/main.backup.tgz
Any ideas how to fix it?
Sounds like the issue is with the containerâs snapshot mountpoint rather than with the backups directory.
What storage backend are you using?
It seems like creating that missing directory may sort things out.
Iâm using zfs.
I just created âmainâ directory in /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots and export went ok.
But now I created a new container and no such directory appeared there, yet new containerâs export went smooth.
So I have a bunch of old containers and they wonât export without creating a directory there. But newly created containers donât need a directory in containers-snapshots.
Whatâs wrong with my old containers? I can create directories, no problem, but may it be a sign of something seriously broken?..
I suspect one thing â locally created containers seem to export ok, but containers with problem are containers copied from another host!
echo Starting backup job at `date`
for c in "${cnt[@]}"; do
echo Backing up container $c
echo ...stopping local copy -- just in case of running, but it should NOT be running
lxc stop $c
echo ...deleting local copy
lxc delete $c
echo ...stopping remote container
lxc stop ns:$c
echo ...deleting old snapshot
lxc delete ns:$c/backup
sleep 1
echo ...making snapshot
lxc snapshot ns:$c backup
echo ...starting remote container
sleep 1
lxc start ns:$c
echo ...copying
lxc copy ns:$c/backup $c
echo ...deleting snapshot
echo ...done backing up $c at `date`
done;
This host is standby host, so live containers are copied from active server and later everything is exported for offline backup. So if I create a new container on active server it will be copied too and Iâd expect export working as well.
Finally I can reproduce this problem:
- Host A: primary host, debian 9, lxc 4.2 via snap,
- Host B: standby host, debian 10, lxc 4.2 via snap
If I create a container on host B and export it then I can export it just fine. If I create a container on host A then I can export it locally, no problem.
But if I create a container on host A and copy that container from A to B via lxc copy THEN I canât export it on host B:
Error: Create backup: Backup create: Failed to create mount directory "/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/test/backup": mkdir /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/test/backup: no such file or directory
If I create required subdirectory on host B (in this case containerâs name was test) then export will workâŠ
Canât reproduce it with new containers anymore. Now if I create new containers on host A they export ok on host B. Old containers still donât export without corresponding subdirectory in /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/
The only difference is recent reboot of host A, it had an uptime of 58 days and I rebooted it today.
HostB:
Non-exportable container:
hostB# lxc config show alp --expanded
image.architecture: amd64
image.description: Alpine 3.9 amd64 (20190321_13:00)
image.os: Alpine
image.release: "3.9"
image.serial: "20190321_13:00"
volatile.apply_template: copy
volatile.base_image: 0cbd911b5a203c7e475241b8b22cc5332d10fd30ae27916bae1558bcb118c9ce
volatile.eth0.hwaddr: 00:16:3e:0b:21:d1
volatile.idmap.base: "0"
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
nictype: bridged
parent: lxdbr0
pool: default
Exportable new container:
hostB# lxc config show test --expanded
image.description: Alpine 3.11 amd64 (20200612_13:00)
image.os: Alpine
image.release: "3.11"
image.serial: "20200612_13:00"
image.type: squashfs
volatile.base_image: 4d5d20957dffb6d92ac16c03a7d1a27ece4d8a09d29863e22adb5ae2c15a102c
volatile.eth0.hwaddr: 00:16:3e:8b:4e:c5
nictype: bridged
parent: lxdbr0
pool: default
Diff between them:
4c4
< image.description: Alpine 3.9 amd64 (20190321_13:00)
6,7c6,8
< image.release: "3.9"
< image.serial: "20190321_13:00"
9,10c10,11
< volatile.base_image: 0cbd911b5a203c7e475241b8b22cc5332d10fd30ae27916bae1558bcb118c9ce
< volatile.eth0.hwaddr: 00:16:3e:0b:21:d1
13c14
< volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
> volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000000000},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
All newly created containers export ok, old containers require creating subdirectory every time.
HostA (source of containers, both conainers export okay there):
hostA# lxc config show alp --expanded:
image.os: Alpine
volatile.eth0.host_name: veth9c50b8f2
volatile.eth0.hwaddr: 00:16:3e:6b:04:12
nictype: bridged
parent: lxdbr0
pool: tank
hostA# lxc config show test --expanded
image.os: Alpine
volatile.eth0.hwaddr: 00:16:3e:64:d2:0a
nictype: bridged
parent: lxdbr0
pool: tank
Diff between them:
4c4
6,10c6,10
< volatile.eth0.host_name: veth9c50b8f2
< volatile.eth0.hwaddr: 00:16:3e:6b:04:12
14,15c14,15
< volatile.last_state.power: RUNNING
> volatile.last_state.power: STOPPED
Something happens when old container is copied from hostA to hostB via lxc copyâŠ
Thanks, please can you log an issue and will try to recreate.
Just logged an issue #7532
