Hi!
Experiencing some troubles with LXD daemon: it refusing to start (and config) after host system migration.
Some history:
- Host installed as Root-on-ZFS, with separate
hostname-zroot\lxd
dataset for LXD only. - Initially LXD configured to use this dataset, inside host zpool
- Host migrated from two zpools (
hostname-zroot
andhostname-srv
) to one, namedhostname
- Then, LXD daemon wont nor start nor configure
This receipt not working, because LXD team updated databases location and format.
Workaround with create temporary pool, destroy all snaps and containers, destroy pool, move dataset, create brand new one for LXD, make send/receive and try to recover lost containers are unacceptable. Too much dances for simple sed
task.
My data are safe and loud. All I need, is just erase 6 chars in config.
