Exactly the same as you did except I mount the image to /DATA instead of /mnt/DATA
~ lxc info --show-log lemp 1 ✘ 5s
Status: STOPPED
Type: container
Created: 2022/07/01 09:29 WIB
Last Used: 2022/07/01 09:38 WIB
Log:
lxc lemp 20220701023825.325 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc lemp 20220701023825.326 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3598 - newgidmap binary is missing
lxc lemp 20220701023825.326 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc lemp 20220701023825.419 ERROR conf - ../src/src/lxc/conf.c:mount_entry:2459 - Operation not permitted - Failed to mount "/var/snap/lxd/common/lxd/devices/lemp/disk.nginx.etc-nginx" on "/var/snap/lxd/common/lxc//etc/nginx"
lxc lemp 20220701023825.419 ERROR conf - ../src/src/lxc/conf.c:lxc_setup:4375 - Failed to setup mount entries
lxc lemp 20220701023825.419 ERROR start - ../src/src/lxc/start.c:do_start:1275 - Failed to setup container "lemp"
lxc lemp 20220701023825.419 ERROR sync - ../src/src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 3)
lxc lemp 20220701023825.426 WARN network - ../src/src/lxc/network.c:lxc_delete_network_priv:3631 - Failed to rename interface with index 0 from "eth0" to its initial name "vethe55eebe3"
lxc lemp 20220701023825.426 ERROR lxccontainer - ../src/src/lxc/lxccontainer.c:wait_on_daemonized_start:877 - Received container state "ABORTING" instead of "RUNNING"
lxc lemp 20220701023825.426 ERROR start - ../src/src/lxc/start.c:__lxc_start:2074 - Failed to spawn container "lemp"
lxc lemp 20220701023825.426 WARN start - ../src/src/lxc/start.c:lxc_abort:1039 - No such process - Failed to send SIGKILL via pidfd 17 for process 5199
lxc lemp 20220701023830.483 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc lemp 20220701023830.483 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3598 - newgidmap binary is missing
lxc 20220701023830.502 ERROR af_unix - ../src/src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20220701023830.502 ERROR commands - ../src/src/lxc/commands.c:lxc_cmd_rsp_recv_fds:127 - Failed to receive file descriptors for command "get_state"
I can also confirm that ext4 loop device works ok.
When I rollback LXD to 5.1, everything came back!
tomp
(Thomas Parrott)
July 1, 2022, 1:08pm
24
What filesystem is this on?
C0rn3j
(Martin)
July 2, 2022, 9:49am
25
I think we are hitting the same issue.
Ubuntu 20.04 host, Ubuntu 20.04 container, LXD 5.3, currently booted on 5.4.0-113-generic
kernel, /var/snap/lxd/common/lxd on btrfs.
This has started happening on a container that worked fine previously.
We can work around the issue by setting the container as privileged.
lxc ourcontainer 20220702094110.198 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc ourcontainer 20220702094110.198 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3598 - newgidmap binary is missing
lxc ourcontainer 20220702094110.200 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc ourcontainer 20220702094110.200 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3598 - newgidmap binary is missing
lxc ourcontainer 20220702094110.201 WARN cgfsng - ../src/src/lxc/cgroups/cgfsng.c:fchowmodat:1252 - No such file or directory - Failed to fchownat(40, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
lxc ourcontainer 20220702094110.343 ERROR conf - ../src/src/lxc/conf.c:mount_entry:2459 - Operation not permitted - Failed to mount "/var/snap/lxd/common/lxd/devices/ourcontainer/disk.aadisable.sys-module-apparmor-parameters-enabled" on "/var/snap/lxd/common/lxc//sys/module/apparmor/parameters/enabled"
lxc ourcontainer 20220702094110.344 ERROR conf - ../src/src/lxc/conf.c:lxc_setup:4375 - Failed to setup mount entries
lxc ourcontainer 20220702094110.344 ERROR start - ../src/src/lxc/start.c:do_start:1275 - Failed to setup container "ourcontainer"
lxc ourcontainer 20220702094110.344 ERROR sync - ../src/src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 3)
lxc ourcontainer 20220702094110.357 WARN network - ../src/src/lxc/network.c:lxc_delete_network_priv:3631 - Failed to rename interface with index 0 from "eth0" to its initial name "veth981c4d9c"
lxc ourcontainer 20220702094110.357 ERROR lxccontainer - ../src/src/lxc/lxccontainer.c:wait_on_daemonized_start:877 - Received container state "ABORTING" instead of "RUNNING"
lxc ourcontainer 20220702094110.357 ERROR start - ../src/src/lxc/start.c:__lxc_start:2074 - Failed to spawn container "ourcontainer"
lxc ourcontainer 20220702094110.357 WARN start - ../src/src/lxc/start.c:lxc_abort:1039 - No such process - Failed to send SIGKILL via pidfd 41 for process 2428210
lxc ourcontainer 20220702094115.677 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3592 - newuidmap binary is missing
lxc ourcontainer 20220702094115.677 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3598 - newgidmap binary is missing
lxc 20220702094115.738 ERROR af_unix - ../src/src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20220702094115.738 ERROR commands - ../src/src/lxc/commands.c:lxc_cmd_rsp_recv_fds:127 - Failed to receive file descriptors for command "get_state"
I’m hitting this error as well, but only on NFS shares (mounted on the host) added as devices to the containers. Other containers that have regular folders from ext4 drives shared to them start fine.
This is on Jammy, kernel 5.15.0-40-generic. As others have done, reverting the LXD snap to 5.2 allows starting the containers with the same nfs shares without issues.
Edit: the containers storage is btrfs
ItsMattL
(Matt LaPlante)
July 3, 2022, 4:19pm
27
I ran into this out of the blue today as well. One observation is that config device add does not exhibit the failure while the container is running, even for the exact same disks that cause the container to fail during startup.
This works fine:
lxc start tester
lxc config device add tester test1 disk source=/data/prizm/nasfs/dvr path=/mnt/dvr
But then lxc exec tester reboot… and the instance fails to come back up. Remove the disk, instance starts. Run device add again and it works, until you restart the container.
tomp
(Thomas Parrott)
July 3, 2022, 4:49pm
28
Thanks, that suggests it is perhaps some regression in liblxc itself rather than lxd, or done difference in how the disk devices are passed at start time vs when running. This is a useful data point and I’ll try and recreate it. Thanks
tomp
(Thomas Parrott)
July 3, 2022, 7:16pm
29
isolin
(Isolin)
July 4, 2022, 12:01am
30
I can confirm that it fixed the problems for me
Fixed here as well. NFS mounts are shared properly with containers (switching to latest/candidate channel and updating to 5.3-924be6a)
Fixed my problem too after update to latest
