Please start a broken container and show the output of:
ip a
and bridge link show
, lxc config show <instance>
on the host.
ip a
on the host.
ip a
inet6 ::1/128 scope host
2: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 24:4b:fe:0c:5c:09 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.239/24 brd 192.168.1.255 scope global dynamic noprefixroute enp5s0
valid_lft 86332sec preferred_lft 86332sec
inet6 fe80::264b:feff:fe0c:5c09/64 scope link noprefixroute
3: lxdbr1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:ba:47:ea brd ff:ff:ff:ff:ff:ff
inet 10.4.101.1/24 scope global lxdbr1
inet6 fd42:9c75:2e7d:6b8::1/64 scope global
inet6 fe80::216:3eff:feba:47ea/64 scope link
5: veth25bd57c2@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr1 state UP group default qlen 1000
link/ether a6:ac:9c:96:6d:9e brd ff:ff:ff:ff:ff:ff link-netnsid 0lxc config show Caixa
WARNING: cgroup v2 is not fully supported yet, proceeding with partial confinement
image.architecture: amd64
image.description: ubuntu 16.04 LTS amd64 (release) (20200708)
image.label: release
image.os: ubuntu
image.release: xenial
image.serial: “20200708”
image.type: squashfs
image.version: “16.04”
volatile.base_image: 6be2a8c660ebaf93a5ea10b2313edc0804375c44bfcb39c76c45900fe1647376
volatile.eth0.host_name: veth25bd57c2
volatile.eth0.hwaddr: 00:16:3e:07:c0:74
volatile.idmap.base: “0”
volatile.idmap.current: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.idmap.next: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.last_state.idmap: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.uuid: 6ecebd5d-221d-49b7-b039-c7329ff2bd18
Downloads:
path: /home/ubuntu/Downloads
source: /home/alex/Downloads
description: “”bridge link show
5: veth25bd57c2@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master lxdbr1 state forwarding priority 32 cost 2
I can’t figure why this time lxdbr1 was UP. No other container was running.
Its up because veth25bd57c2
is connected to it, and the other end of veth25bd57c2
will be inside the container Caixa
, you can see from the volatile.eth0.host_name: veth25bd57c2
entry that it all lines up.
That’s right about veth. Instead, I still have no idea on how to fix this network issue.
The difficulty I’m having is that I can’t get a clear picture of what is going on on your machine or what config you have set, as each time I ask it appears to have changed.
Unless we stablise the config and get a clear reproducer of the issue along with a snapshot recording of the interface state and dnsmasq listeners at the time, along with a tcpdump of the traffic on the bridge at the time the instance was starting (in order to capture the DHCP request and confirm its actually happening) then I am not going to be able to advise further.
I understand. I’m sorry because I’ve messed with those settings while trying to get your help. Furthermore, I wasted to much of your precious time, for which I want thank you so much. I think the best solution in this case will be to migrate old containers to new ones.
Sounds good.
It could be that something on your system (NetworkManager perhaps) is trying to manage the lxdbr1 interface and is interfering with LXD’s operation of it.
